It is currently Tue Jul 08, 2025 1:23 pm
PostPosted: Sun Sep 23, 2007 7:21 am
Not sure if its been asked,
saw a mini race car with a solid rear axle set up, using two motor bike coil overs. he said it works VERY well.
can you use them in the front?
just a question :)
PostPosted: Sun Sep 23, 2007 10:54 am
Sure, why not. Two per side maybe.
PostPosted: Sun Sep 23, 2007 12:48 pm
norm gowers with the vtec mini has motorbike coil overs in the rear
PostPosted: Sun Sep 30, 2007 5:37 pm
What type of motor bike do you know?
thanks everyone
PostPosted: Sun Sep 30, 2007 5:41 pm
You'd probably have to modify the mounts though as the mini coilovers have the top mount offset to keep the normal shock geometry standard . Hard to describe but look at the top of the coilovers on ebay etc and you'll see .
PostPosted: Mon Oct 01, 2007 8:44 am
thanks for that, 415 mm is a bit long though, oh well ill keep an eye out for a set worth using. cheers
PostPosted: Mon Oct 01, 2007 5:42 pm
have you seen this?
http://www.minisport.com.au/prod323.htm
PostPosted: Mon Oct 01, 2007 7:43 pm
Yes, I have. I am looking at getting a set, thought I might be able to get away with using motor bike ones in the rear, and mini ones in the front. but looks like ill be getting a set.
I think thats a really good price also.
PostPosted: Wed Oct 10, 2007 5:54 pm
I put motor bike coil overs on my old mini many many years ago. They bent to an...... interesting shape :) I ended up getting a set of bilsteins made for it.. cost a friggen fortune and was soooo NOT worth it. But meh I could say that about most of the mods I did in my youth :)
PostPosted: Thu Oct 11, 2007 10:55 am
Motorcycle coil overs seem pretty pointless considering you couldn't even buy 2 suitable units for the price of the SPAX conversion. That and you can guarantee that the spring rate would be incorrect, not having been made with Minis in mind. :wink:
PostPosted: Thu Oct 11, 2007 11:06 pm
dunno about the front because of engine weight but i know they work on a rear beam.. i have one in my race car.. dunno what they are off.. i think 1375 or whatever the coil kit costs is a little too much too.. shop around..
Potato
Users browsing this forum: No registered users and 26 guests
