https://ausmini.com/forums/
ground clearance
https://ausmini.com/forums/viewtopic.php?f=5&t=36240
Author:  andywado [ Sun Sep 30, 2007 6:04 pm ]
Post subject:  ground clearance
I was reading the manual and it says the ground clearance should be around 6 ins Ive got about 4 it looks cool but F#&K its low what do I do to get the height back up to spec?
Author:  drmini in aust [ Sun Sep 30, 2007 7:51 pm ]
If it's still hydro suspension, you get it pumped up by someone with a hydro pump.
I've got one- but Can-Bra is a bit far to go, check out your local Mini club. :wink:
Author:  andbat [ Sun Sep 30, 2007 8:00 pm ]
and if it not hydro. replace the rubber thingos or install adjustable cones, or both. right doc.?
Author:  1018cc [ Sun Sep 30, 2007 8:21 pm ]
Translation: If you have dry suspension try replacing the rubber cones or install Hi-Lo's (or similar) or both. Your cones might be fine (I doubt it unless you have replaced them recently) and some one has cut down the trumpets thus lowering the car.
Author:  andywado [ Sun Sep 30, 2007 8:57 pm ]
It's a hydro Doc. The displacers seem ok. A pump up might do the trick you think?
Author:  9YaTaH [ Sun Sep 30, 2007 9:01 pm ]
Post subject:  Yep
Yes...it could do...unless the front trumpets have punched through there cups/mountings...the club has a pump as does Melba Mtrs.
Author:  buztoy [ Sun Sep 30, 2007 9:15 pm ]
adjustable cones
are there really :? :o
Author:  drmini in aust [ Sun Sep 30, 2007 9:31 pm ]
buztoy wrote:
adjustable cones
He means Hi-Los. :wink:
