https://ausmini.com/forums/
can you ?
https://ausmini.com/forums/viewtopic.php?f=5&t=36048
Author:  russdog1 [ Mon Sep 24, 2007 8:39 pm ]
Post subject:  can you ?
Hi, all , can you dismantle a remote shift (mini K ) type diff assemble & fit pot type joints? Will be making some reasonable HP in the future & I'm no expert but these rubber uni things just don't look strong !!
Author:  slinkey inc [ Mon Sep 24, 2007 9:10 pm ]
I'm using Cooper S steel universal joints, and for me they've held together on well over standard Cooper S power. Pot joints should be fine also, but I think the rubber joints might not be as bad as you think.
I'm sure someone one here will have put loads of power and torque through a set of these.
Author:  willy [ Mon Sep 24, 2007 9:13 pm ]
Yeah not an issue at all.
Diff needs changing for pot joint outputs.
And the diff end covers need machining up to clear some casing parts.
Not a big job.
I think Chong / Dr Mini can fill you in with pictures. That'll help you.
Author:  DOZ [ Mon Sep 24, 2007 9:35 pm ]
Rubber joints were designed for std engines and are crap. I would put pot joints on for sure.
Daniel
Author:  russdog1 [ Mon Sep 24, 2007 11:01 pm ]
Post subject:  can you?
Whilly when you say change the diff, can i use pot type diff centre bolted to the original crownwheel & fitted into the original diff housing ? With some external mods for clearance of the pots . Is that right? Thanks Russell
Author:  drmini in aust [ Tue Sep 25, 2007 7:45 am ]
Post subject:  Re: can you?
Just take diff out and swap the early output shafts and yokes for some pot joint ones. Side covers you have fit OK. :wink:
Pot joints are strong, maybe not as bulletproof as Hardy Spicer `S' ones but good enough for most purposes. And on a road car they take less upkeep.
Author:  russdog1 [ Tue Sep 25, 2007 7:39 pm ]
Thanks for the reply's guys - great help , Russdog
