It is currently Tue Jul 08, 2025 1:32 pm
 Post subject: Individual gear ratios?
PostPosted: Tue Sep 18, 2007 10:07 pm
Location: Melbourne, Australia (car); Savannah (GA), USA (me)
Dumb question time... :oops:
Can you change out individual gear ratios in a A/A+ gearbox? I know the VW boys do it all the time, in Beetles and the like.
I have a couple of late model A+ 1275cc Mokes, but third gear just seems like such a step up from second. For me, it's just that bit too tall and I really miss that sense of urgency.
Can I make third that bit shorter and fourth that bit taller? I'm not really interested in modifying the final drive (i.e. no diff ratio change suggestions).
PostPosted: Tue Sep 18, 2007 10:20 pm
A+ ratios are particularly bad. They are wider than std A series 4 synchro.
Only way on them really is change the whole gearset.
A+ box-
You can either get a full close ratio straight cut set (noisy) or with a few mods you can fit Cooper S ratios. But the whole gearset needs to be changed for this as A+ gears have different teeth angles.
A series- 4 synchro remote, or Oz rodchange:
You can get Cooper S ratios by changing just the 1st motion shaft and the cluster gear. However, this only closes up the 3-4 gap slightly, 2-3 is the same gap.
Fitting these gears raises 1, 2 and 3 by 1/17th. 4th stays the same (1:1).
To do what your VW mates do you would need a modular cluster gear and a selection of 1st 2nd and 3rd. These aren't made for Minis, except the latest Swiftune racing dog boxes from UK which cost megabux.
PostPosted: Wed Sep 19, 2007 8:16 am
Thanks Doc.
I guess that's something to think about on the the second Moke (as I rebuild it)... but definitely won't be happening to MOKEME anytime soon. :(
PostPosted: Wed Sep 19, 2007 8:21 am
My 1132cc Moke is just getting a standard Oz Clubby rodchange box. Diff will be a 3.44 as it's going to run 13s with low profile rubber.
:wink:
PostPosted: Thu Sep 20, 2007 12:58 am
My brother last week has put a recon S box on and its fantastic. I think the S/C gears are better for ratios but he is happy with the S box.
Or ritey - Classic Minis Only For Me
PostPosted: Sun Sep 23, 2007 5:33 am
i like the standard 3.44 box ratios but
4th is too tall for the twisties and too short for highway work.
PostPosted: Sun Sep 23, 2007 7:41 am
meh... I run a 3.65 in the 1360, and earplugs on the freeway. 8)
Can climb trees in 4th gear.. or seems like it.
PostPosted: Sun Sep 23, 2007 4:58 pm
I run a 3.6 and love it and just to mix things up a bit it's a A+ gear set inside a remote box
gears are nice and close and the fearchange feels great..
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Sun Sep 23, 2007 4:59 pm
gears are nice and close and the gearchange feels great..
HOTBRICKS
'65 NCF MINI.....
Users browsing this forum: No registered users and 26 guests
