can you use motor bike coil overs? https://ausmini.com/forums/viewtopic.php?f=5&t=35984 |
Author: | -=MiniMafia=- [ Sun Sep 23, 2007 7:21 am ] |
Post subject: | can you use motor bike coil overs? |
Not sure if its been asked, saw a mini race car with a solid rear axle set up, using two motor bike coil overs. he said it works VERY well. can you use them in the front? just a question ![]() |
Author: | JC [ Sun Sep 23, 2007 10:54 am ] |
Sure, why not. Two per side maybe. |
Author: | dove grey 64 [ Sun Sep 23, 2007 12:48 pm ] |
norm gowers with the vtec mini has motorbike coil overs in the rear |
Author: | -=MiniMafia=- [ Sun Sep 30, 2007 5:37 pm ] |
What type of motor bike do you know? thanks everyone |
Author: | sports850 [ Sun Sep 30, 2007 5:41 pm ] |
You'd probably have to modify the mounts though as the mini coilovers have the top mount offset to keep the normal shock geometry standard . Hard to describe but look at the top of the coilovers on ebay etc and you'll see . |
Author: | -=MiniMafia=- [ Mon Oct 01, 2007 8:44 am ] |
thanks for that, 415 mm is a bit long though, oh well ill keep an eye out for a set worth using. cheers |
Author: | Spaceboy [ Mon Oct 01, 2007 5:42 pm ] |
have you seen this? http://www.minisport.com.au/prod323.htm |
Author: | -=MiniMafia=- [ Mon Oct 01, 2007 7:43 pm ] |
Yes, I have. I am looking at getting a set, thought I might be able to get away with using motor bike ones in the rear, and mini ones in the front. but looks like ill be getting a set. I think thats a really good price also. |
Author: | miki [ Wed Oct 10, 2007 5:54 pm ] |
I put motor bike coil overs on my old mini many many years ago. They bent to an...... interesting shape ![]() ![]() |
Author: | Anto [ Thu Oct 11, 2007 10:55 am ] |
Motorcycle coil overs seem pretty pointless considering you couldn't even buy 2 suitable units for the price of the SPAX conversion. That and you can guarantee that the spring rate would be incorrect, not having been made with Minis in mind. ![]() |
Author: | meeni [ Thu Oct 11, 2007 11:06 pm ] |
dunno about the front because of engine weight but i know they work on a rear beam.. i have one in my race car.. dunno what they are off.. i think 1375 or whatever the coil kit costs is a little too much too.. shop around.. |
