1970 roundnose https://ausmini.com/forums/viewtopic.php?f=5&t=35828 |
Author: | andywado [ Mon Sep 17, 2007 3:16 pm ] |
Post subject: | 1970 roundnose |
Hi. I just replaced the front suspension on my 1970 roundnose. ie:ball joints, rubber bushes, wheel bearings. It's ow making a rumbling grinding noise from the front left. It makes the noise in the straight line and with the wheel on lock. it wasn't doing this before the refit any ideas??? ![]() |
Author: | Mick [ Mon Sep 17, 2007 3:18 pm ] |
Have another look at the nuts on the end of the drive shafts, if they are not torqued up correctly, this will cause the assemble to rumble. |
Author: | simon k [ Mon Sep 17, 2007 5:26 pm ] |
pull it apart again and check everything.... it's not hard to forget something |
Author: | andywado [ Wed Sep 19, 2007 8:57 am ] |
Hi Mick by the nuts on the driveshaft what do you mean. I have rubber unis which I replaced. Andy |
Author: | Mini Mad [ Wed Sep 19, 2007 10:31 am ] |
I think mick means the nut on the CV end, if you pulled it apart to do wheel bearings, what did you torque it back up to? |
Author: | andywado [ Wed Sep 19, 2007 9:55 pm ] |
Hi mini mad I didn't torque it, do you know the setting. I've checked everythng else and they look ok. Andy |
Author: | Mini Mad [ Wed Sep 19, 2007 10:15 pm ] |
Did you just tighten the nut as tight as you could? or what? be careful, if you over tightened the CV thread may be cactus ![]() If you hold the wheel at 12 and 6 and try to wiggle it is there any play/movement? These are the torque settings: If Drum Brakes - 60ft/lb If Disk Brakes - 150ft/lb ![]() <edit> be careful with this because if that nut comes undone, you will probably become a passenger ![]() While i'm here did you torque the ball joints up either?? |
Author: | andywado [ Wed Sep 26, 2007 11:28 pm ] |
I've taken the drive shaft out again and the bearing hasnt stayed in the hub its on the stud plate could the bearing be turning in the hub? |
Author: | 9YaTaH [ Thu Sep 27, 2007 6:51 pm ] |
Post subject: | ACTMCC |
Hi Andy...make contact with the Mini Club....someone local can come around and have a geek at the problem....I wouldn't drive it like it is ![]() Cheers, Mick |
Author: | andywado [ Fri Sep 28, 2007 7:20 am ] |
Thanks mick, I will do that. it's driving me nuts at the moment. But thats what happens when you own an individual like a mini. you either love them or you hate them, theres no in between. true? ps. how do you get a picture inserted like you have. I've tried but it says the file size is too big. Andy ![]() |
Author: | Blunder [ Fri Sep 28, 2007 9:06 am ] |
Post subject: | noodle |
If you mean the bearing cup or race as some call it hasn't stayed in the hub then you need to noodle the inside edge of the hub so the cup/race is a tight interference fit, if its loose in the hub then it turn and scrub creating noise. |
Author: | andywado [ Fri Sep 28, 2007 9:10 am ] |
Noodle?? ![]() |
Author: | Blunder [ Fri Sep 28, 2007 9:17 am ] |
Basically you get a hammer and punch, then mark the inner of the hub, as you make a punch mark the outer edge of the indent is pushed up, so say do it in 4 places evenly around the inner edge of hub then should be tight. that help?? |
Author: | andywado [ Fri Sep 28, 2007 2:30 pm ] |
I'll give it a go thanks mate |
Author: | 9YaTaH [ Fri Sep 28, 2007 4:41 pm ] |
Post subject: | Avatar |
andywado wrote: Thanks mick, I will do that. it's driving me nuts at the moment. But thats what happens when you own an individual like a mini. you either love them or you hate them, theres no in between. true? ps. how do you get a picture inserted like you have. I've tried but it says the file size is too big.
Andy ![]() Don't usually give forum help...but here goes...it is called an Avatar and I think its limited to something like 100 be 100 pixels...try uploading a picture in update profile.... ![]() |
