It is currently Mon Jul 07, 2025 1:29 pm
 Post subject: Valve guides
PostPosted: Mon Sep 03, 2007 9:41 pm
I just pressed out the valve guides on a couple of heads I have here and I noticed that the exhaust ones were almost melted all the way down to the guide boss. Is this just a wear type thing or was there something seriously wrong with the engine?
I am thinking about using the magnesium guides anyway. Would this be a good idea?
Also if I use the better type guides would it be better not to use a valve stem seal on the exhausts like vizard says?. I am assuming this would make them less inclined to melt?
Thanks ya'll
blokeinamoke wrote:
PostPosted: Mon Sep 03, 2007 10:03 pm
These days with unleaded fuel unless you are using 21/4N stainless steel valves with unplated stems (like me) I would use the stock cast iron guides.
The other guides you are thinking of are manganese bronze, not magnesium (which would last about 5 seconds). :wink:
these are the ones I use in my 1360 for reason above.
I never use valve stem seals on the exhausts, there is no vacuum there (unlike the inlets) and as Vizard says they need some lube for heat transfer. Particularly bronze ones- they can seize with no lube.
I know that BL/Rover fitted seals to all 8 valves from around 1980 onwards, but they are pretty ineffective once they go hard. It doesn't take long at all.... :lol:
