Rear drums & S rear drums https://ausmini.com/forums/viewtopic.php?f=5&t=35234 |
Author: | Fat Boy Dave [ Tue Aug 28, 2007 7:41 pm ] |
Post subject: | Rear drums & S rear drums |
Is there any difference between regular rear drum brakes and those found a disc brake Mini? |
Author: | drmini in aust [ Tue Aug 28, 2007 7:54 pm ] |
There are really only 3 different type drums, they are all same dimensions inside though (7" bore) and take the same brake shoes, 1-1/4" wide on rear.. Flat drums- used on all Minis with 3-1/2" wide rims, including 997-998 Cooper and Clubby. 1" spacered drums- used on Cooper S, Clubman GT and Clubby S. 3/4" spacered drums- used on big wheel Mokes. Note the Cooper S and Clubby S drums have all the same dimensions, but the Clubby S one has a plain bore in the hub where the Cooper S/GT is cast a fluted shape. Both these drums fit the same... Note if using spacered drums you need the longer wheel studs... ![]() |
Author: | sgc [ Tue Aug 28, 2007 7:58 pm ] |
Post subject: | Re: Rear drums & S rear drums |
Fat Boy Dave wrote: Is there any difference between regular rear drum brakes and those found a disc brake Mini?
The slave cylinders on the rear of a disc braked car are smaller than on a drum front, to prevent the rears from locking. Cooper S rear cylinders are ⁵⁄₈" IIRC, while it's common to find ¾" slaves on the rear of a drum braked car. I'm not sure there's any difference in the drum width... (Hi from Kingsville, btw ![]() --s |
Author: | drmini in aust [ Tue Aug 28, 2007 8:04 pm ] |
S and GT rear wheel cylinders are 5/8" diameter. It's a good idea to fit these to any drum braked Mini when you fit S front discs or bigger. Getting sideways on the freeway at 110 cliks is not funny.... as I found out once. |
Author: | sgc [ Tue Aug 28, 2007 8:39 pm ] |
drmini in aust wrote: S and GT rear wheel cylinders are 5/8" diameter.
It's a good idea to fit these to any drum braked Mini when you fit S front discs or bigger. Yeah, I'm replacing drums with 4-pot 7.5" discs in a few weeks.. going to see how we go with the ¾" rears before swapping them ![]() |
