mini-dunger wrote:
I thought the guides were all the same? I am using 1100s valves so should I be looking for any ones in particular? or just "mini" ones? Either way milling them down and re bullet nosing them again is no big deal. The depth that then need to be pushed in would be written some where in a manual shouldnt it?
Thanks Kev
On a smallbore 998 head the guides are 15.5mm above the spring seats (I just measured a mint 998 Clubby one).
On a 940 (ie 1100S) head they are about 14mm above the spring seats.
Note these spring seats are different depth to a smallbore.
As you are using 1100S valves, (which are 2mm longer stems) in a smallbore head, I would leave the top of guides 16 or 17mm above spring seats, and leave them stock length- they should be OK.
