Engine Block Rebuild questions......... Morris 1100S https://ausmini.com/forums/viewtopic.php?f=5&t=35021 |
Author: | Smarty [ Mon Aug 20, 2007 10:05 pm ] |
Post subject: | Engine Block Rebuild questions......... Morris 1100S |
Just a couple of questions regarding an 1100S(1275) block rebuild that I am undertaking at the moment.... 1. What thread is the temp sender? I need to tap it out, but the one I took out was a bit crossed up and I cant tell what it should be. 2. In the Vizard book they recommend that you drill and tap the gearbox bolt holes to 5/16 and use bigger bolts. Is this necessary or just a waste of time? If a good idea then do I need to use hardened bolts or will other ones suffice? Thanks everyone in advance!! |
Author: | drmini in aust [ Mon Aug 20, 2007 10:43 pm ] |
Post subject: | Re: Engine Block Rebuild questions......... Morris 1100S |
Smarty wrote: Just a couple of questions regarding an 1100S(1275) block rebuild that I am undertaking at the moment....
1. What thread is the temp sender? I need to tap it out, but the one I took out was a bit crossed up and I cant tell what it should be. 2. In the Vizard book they recommend that you drill and tap the gearbox bolt holes to 5/16 and use bigger bolts. Is this necessary or just a waste of time? If a good idea then do I need to use hardened bolts or will other ones suffice? Thanks everyone in advance!! Q1. 5/8-18 UNF or 5/8-16 UNS thread, depending which guru you talk to. I tap them with the former, you can actually buy taps here this size. ![]() Q2. I had an ex-race Mk1 S motor with the block tapped out to 5/16 UNF. I believe it's a waste of time unless: a.It's a race motor and b. It's an early thin flange block. I've never had an oil leak problem there with the stock 1/4" bolts in 1100S blocks, these bolts are Grade 5 and quite adequate. If you want stronger, buy Grade 12 Unbrako socket head bolts instead. |
Author: | Smarty [ Mon Aug 20, 2007 11:03 pm ] |
Thanks Doc. Oh yeah the other question was also vizard related. What thread should I tap out the oil gallery plug holes? |
Author: | simon k [ Tue Aug 21, 2007 9:03 am ] |
Smarty wrote: Thanks Doc.
Oh yeah the other question was also vizard related. What thread should I tap out the oil gallery plug holes? whatever thread you can get a good supply of bolts in, but given it's a cast iron block, UNF would be the go |
Author: | drmini in aust [ Tue Aug 21, 2007 5:36 pm ] |
skssgn wrote: Smarty wrote: Thanks Doc. Oh yeah the other question was also vizard related. What thread should I tap out the oil gallery plug holes? whatever thread you can get a good supply of bolts in, but given it's a cast iron block, UNF would be the go The holes are 1/2" now. 9/16" UNF would be nice, (I even have a tap) but 9/16 UNF grub screws are unobtainium. ![]() You could drill out a bit and use 5/8" UNF ones. I'm probably tapping mine 14mm next time- instead of just turning up new brass ones and bashing them in. ![]() |
Author: | Smarty [ Tue Aug 21, 2007 9:40 pm ] |
Thanks guys Also what length unbrako gearbox 1/4 inch bolts should I buy (dont actually have any to compare against. Do the oil gallery plugs need to be tapered? or will just ordinary do with a bit of sealant of some sort? sorry for the dumb questions but I wont know the answers untill I ask the questions. Regards Smarty |
Author: | drmini in aust [ Tue Aug 21, 2007 10:07 pm ] |
Not sure of the bolt lengths, but there are several you will need. Fronts longer than the backs, and 2 near the crank pulley are shorter still. Parallel thread hex plugs are fine, just smear a bit of Loctite on them to seal. Do NOT use teflon tape, it'll get into places it shouldn't. ![]() |
