https://ausmini.com/forums/
Requirements to Turbocharge Mini
https://ausmini.com/forums/viewtopic.php?f=5&t=33459
Author:  spankys13 [ Sun Jul 01, 2007 9:06 pm ]
Post subject:  Requirements to Turbocharge Mini
Hi,
I have a 71 998 Leyland clubman and I have wanted to turbocharge it for a while. Can someone tell me what I would to do this? Eg, What parts are required, and what kind of pre-requisites I should do to my car before attempting this.
Thanks in advance,
Author:  Spaceboy [ Mon Jul 02, 2007 12:47 am ]
easiest way is to get hold of a "metro turbo" setup from the UK
you will need to cut a box section out of your firewall to clear the turbo.
engine mods require lower compression so you can run more boost, a cam suitable for turbocharging and she should be in good running order..
you can do strengthening and lightening and you should definitely choose some good pistons.
Author:  cush [ Mon Jul 02, 2007 1:13 am ]
that was going to be my suggestion
Author:  drmini in aust [ Mon Jul 02, 2007 8:02 am ]
Alternative is build a new compact exhaust manifold like Benjamin did, no need then to cut a box in (which needs engineering certification).
see his thread and pics here- http://www.ausmini.com/forums/viewtopic ... highlight=
Or you could do what kazjim did and mount it above the flywheel housing- this also needs a custom made exhaust manifold. Need to do a search for this one.
Both these manifolds were welded up from steel elbows and tubing then the flanges machined.
Author:  slinkey inc [ Mon Jul 02, 2007 5:30 pm ]
step 1. Go to http://www.turbominis.co.uk and log into the forum.
IMO Metro Turbo is NOT the best way to go. Probably the simplest but not the best. They have a compression of 9.4:1, which is high for a turbo, standard Metro cam (non-MG) basically it's a Metro 1275, with tough pistons and 9.4:1 compression. It has very tough pistons, and better exhaust valve material. Will require firewall modding.
However, a company called Mirage in the UK make special manifold such that no firewall mods are required and there's dyno and quarter mile proof that they make good power.
Above all you need MONEY! But first off log into the forum above, and ask questions, there's stickys on this. I log in once a week on the same name as here.
<edit> Just realised, above, Spaceboy only recommended the turbo set up, not the whole motor. But he mentioned reducing of compression for turbo. Good idea, more boost, more igntion advance, but the Metro Turbo engine run 9.4:1. People on the forum say about 10psi is max for the metro turbo engine set up.
Author:  low n blown [ Thu Jul 05, 2007 10:49 am ]
You are about 3 days too late. Just sold a complete metro turbo engine and box $1500. Had full turbo setup incl plenum, manifold, turbo etc.Sorry.
Author:  pommy#george [ Thu Jul 05, 2007 12:21 pm ]
yeah, you was suppose to sell it to me :(
Author:  low n blown [ Thu Jul 05, 2007 2:37 pm ]
sorry champ. first in best dressed. :cry:
Author:  pommy#george [ Thu Jul 05, 2007 6:49 pm ]
Post subject:  buy this
www.miragemotorsport.com
350 niker,or pounds or $850aus plus postage and tax.
mind you minus,your 17.5% vat from the uk.
so give or take about $680aus.
need to buy your turbo though t2,t25. garrett.
plus hif44 carb.
have look at the web page tells you what you need.
Author:  slinkey inc [ Thu Jul 05, 2007 9:10 pm ]
They look good too!
I reckon they are great! Yes pretty expensive for what they are, but definitely worth it when you don't need to hack up the baulkhead!
Author:  pommy#george [ Thu Jul 05, 2007 9:22 pm ]
just got off the phone with mirage.
340 pounds,there is no vat on this unit.
but the postage is only 30 pounds.
you have to get a hif44 turbo carb of the mg metro,
plus still have get pleneumbb chamber made up,or use the 1 off the metro turbo
