It is currently Sat Jul 12, 2025 6:22 pm
 Post subject: Block cleaning question
PostPosted: Sun Jul 01, 2007 2:27 am
Hi all
I got my motor back from the engine mob and all the oil and water gallerys are still full of crap. I told them to acid bath it but obviously this just loosens the stuff. In a perfect world I would just blast it with a pressure cleaner, but this is obviously not the best idea. I have a Kero gun attachment for my air compressor so I will probly use that.
OK, to the question. Does anyone know where I can get those big pipe cleaners like Vizard mentions?.
Thanks all
blokeinamoke wrote:
PostPosted: Sun Jul 01, 2007 6:47 am
I get a few foam earplugs on a piece of wire and drag em through the main gallery, after I've pressure blasted it with degreaser.
Then I hose it with water, airblast it, put a torch at other end and have a good look through it. I replace the brass plugs at every rebuild (I make new ones).
The smaller galleries to the bearings never seem to get crap stuck in them- I just poke a drill in there after degreasing, and then blow them out. :wink:
PostPosted: Sun Jul 01, 2007 8:31 am
Supercrap do a spray gun cleaning kit that has different size brushes in it, works OK.
Steve
PostPosted: Tue Jul 03, 2007 9:45 am
http://www.redistrip.com.au/Main.htm
PostPosted: Tue Jul 03, 2007 9:18 pm
Chong..thats perfect for Me...Thanks :wink:
