Brakes need bleeding? https://ausmini.com/forums/viewtopic.php?f=5&t=33228 |
Author: | niceboy1275 [ Sun Jun 24, 2007 8:14 pm ] |
Post subject: | Brakes need bleeding? |
Hi, I've almost got my 71 clubby roadworthy, but the brakes are VERY spongy. As in 3 pumps, before they work. Now I've got a fair idea that I need the brakes bled. Thing is, I have limited tools and no real idea what I'm doing ![]() Cheers J p.s. Actually make that 2 clubbys who need brakes bled at my house ![]() |
Author: | Spaceboy [ Sun Jun 24, 2007 9:03 pm ] |
is the pedal spongy after you pump it three times or is it firm? if its spongy you're in trouble, if its firm you just need to adjust it, which you can do with the correct sized spanner and 10 minutes. |
Author: | niceboy1275 [ Sun Jun 24, 2007 9:06 pm ] |
hey man, nah its firm after the 3rd pump. If the pedal travel was 3 times longer, it would be fine ![]() ![]() |
Author: | speedy [ Sun Jun 24, 2007 10:02 pm ] |
I've had the same problem, caused by leaky wheel cylinders. |
Author: | mason [ Mon Jun 25, 2007 7:48 am ] |
Check your adjustment before using brake fluid |
