https://ausmini.com/forums/
welded/locked diff
https://ausmini.com/forums/viewtopic.php?f=5&t=32874
Author:  73GT [ Fri Jun 15, 2007 7:40 am ]
Post subject:  welded/locked diff
Hi all
I'm thinking of trying with on a circuit race mini
is it worth doing, how hard is it to turn at low speed?
Is it just a matter of welding up the spider gears
Any feedback appreciated
Thanks
Stewart
Author:  sports850 [ Fri Jun 15, 2007 7:47 am ]
All I can offer is from friends who raced mini's at Stanthorpe's Carnell Park several years ago , the course was half packed clay , half bitumen and they used locked diffs with rubber uni's and were of the opinion that rubber uni's were the best as they gave a little bit of "give" to make it more usable with the locked diff .
Author:  MINImal effort [ Fri Jun 15, 2007 6:57 pm ]
My NB Historic race car came with a welded locked diff.
It used a front sway bar to lessen grip on one side to help steering.
At speed on the track was OK and quite drivable.
In the pits.... was the pits... real struggle to move away when parked or manouvering onto the trailer. Real hassle and stalled frequently (quite embarassing) unless you used big revs (equally embarassing). If you had to push.... urggg... not fun.
Once on the move slowly was steerable but needed heaps of effort to turn.
Major pain when carrying out maintenance at home and moving around.
If not done right they are potentially dangerous... (Mine was heavily welded up to ensure no issues - basically all internals FILLED with weld.)
I changed to a QUAIFE asap... and is a pure dream in comparison.... but they do cost $$.
In summary wouldn't recommend it ... but can be done...
Author:  Mick [ Fri Jun 15, 2007 7:08 pm ]
I had a mate who did this, and then he used it on the road.
If you let go of the steering wheel (or it was wrenched out of your hands by the sheer torque) then the car would try to turn around in traffic. Good at speed, but bloody dangerous at lower rates of knots.
He shattered his inboard CV's eventually. Luckily in his own driveway when he drove in from the street.
Author:  DOZ [ Sat Jun 16, 2007 9:56 am ]
I witnessed a turbocharged race mini hit the pit wall at Eastern Creek about 10 years ago going 200+kph. The car was a write off and was caused by a locked diff (axle on passenger side snapped, all drive to the right hand front wheel).
Daniel
Author:  dove grey 64 [ Sat Jun 16, 2007 11:24 am ]
Daniel
could be a silly question, but did the guy driving actually live?
Author:  slinkey inc [ Sat Jun 16, 2007 12:32 pm ]
Daniel
I was about to ask the same thing, 200kph+...... :shock:
Author:  DOZ [ Sat Jun 16, 2007 1:33 pm ]
The pit wall runs along the edge of the straight so he hit turning, not straight if you get my drift.
The car broke the shaft just after the start/finish line and took an exteme hard left turn into the wall. The car hit more or less front square against the wall and spun 2 or three times before stopping on the oppsite side grass down near the drag racing start line. The driver got out and took a step or two before collapsing on the ground, no major injuries though.
The whole front of the car was pushed in and the floor/roof was creased etc, write off.
My point is that had he not had a locked diff it wouldn't have happened, it may have blown the engine from over rev though I spose. Whether an LSD would have made a difference I'm not sure but definately an open diff would have not forced the car to turn so violently.
daniel
Author:  73GT [ Mon Jun 18, 2007 7:53 am ]
thanks for the replies
i can now see that there will be a lot of hassles
Not so much at speed on the track.
On the haipins i can see problems with effect trying to turn in
& resulting strain on the driveshafts/joints
But does it reduce lap times?
What is it like in the wet compared to a open diff?
might put this idea on hold
Author:  TheMiniMan [ Tue Jun 19, 2007 1:15 pm ]
A limited slip diff is the go,,, spend the money & buy a Quaife type Torque Bias diff, they are sweet as a nut
I`ve used locked diffs for years on the oval dirt speedway circuits & they work well there--> """When set up properly" in conjunction with the right tyre-stagger & weight jacking to suit each track, but bitumen/tarmac racing is a different kettle of fish, i highly recomend "NOT" using a locked diff for bitumen/tarmac use at all.
The Torque bias diffs are exccellent!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! you will love it & never look back!!!!!!!!
spend the money, it`s very well worth it.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Author:  73GT [ Wed Jun 20, 2007 10:16 am ]
thanks for the advise
looks like something else to add to the wishlist
depending on the circuit would a LSD be worth 2-3sec min improvement on a open diff?
Author:  TheMiniMan [ Wed Jun 20, 2007 2:01 pm ]
depends on the circuit,,, but yes 2secs is pretty roughly right
