Flywheel Ring Gear replacement https://ausmini.com/forums/viewtopic.php?f=5&t=32744 |
Author: | CUB [ Mon Jun 11, 2007 8:42 pm ] |
Post subject: | Flywheel Ring Gear replacement |
G'day guys, Has anyone had to replace a ring gear? Are they easy to replace or is there some tricks that I need to know? Cheers |
Author: | drmini in aust [ Mon Jun 11, 2007 9:00 pm ] |
Here's how I do it: 1. Cut almost through ring gear with angle grinder and cutting disc. DON'T nick the flywheel. 2. Split gear off with a hammer and chisel. Wipe flywheel surface where it sat. Sit flywheel on floor with clutch running face upwards. 3. Sit new ring gear on 3 bricks (firebricks best, otherwise use dry housebricks) with chamfered edge of teeth downwards. 4. Rub top surface of ring gear with emery cloth to polish it a bit. 5. Using an oxy torch, heat the gear evenly all round until it is a dark straw temper colour. Don't let it get to blue, it will soften it. 6. Using 2 pr of tongs or multigrips, pick ring gear up and drop it on the flywheel. Tap it gently and quickly if not fully seated. Note- you will seldom get enough heat for this job with a Primus etc blowtorch, unless it's indoors and it's a warm day. Oxy is so much better as a source of heat. The last thing you want is to have it stick, 1/2 way on... ![]() |
Author: | Mick [ Mon Jun 11, 2007 9:54 pm ] |
I've done this using the wife's oven. She wasn't impressed, but I talked her into it. You only get 250'ish degrees, but I managed to get it on anyways. |
Author: | Bubbacluby [ Tue Jun 12, 2007 9:45 pm ] |
Post subject: | ringear |
i did a ringgear in my clubby (came loose from flywhhel) - i just put another flywheel in i got off a mate Brenton |
Author: | 9/61 [ Fri Jun 15, 2007 12:44 pm ] |
Is it a stock flywheel? You can get an exchange for about $100 inc. pressure plate & flywheel re-machined. Unless you have all the parts already, then this is not good value |
Author: | drmini in aust [ Fri Jun 15, 2007 2:12 pm ] |
9/61 wrote: Is it a stock flywheel? You can get an exchange for about $100 inc. pressure plate & flywheel re-machined. Unless you have all the parts already, then this is not good value
I think you will find that price is for the machining only. A NEW ring gear alone costs $85+ direct from importer (Karcraft). ![]() |
Author: | 9/61 [ Fri Jun 15, 2007 3:27 pm ] |
Post subject: | Fly wheel exchange |
Mini and moke world Brookvale in Sydney 9938 2242 Do a flywheel and pressure plate exchange. You give them your flywheel inc. ring gear and pressure plate and they give you a reconditioned set for $99. You can't argue with that! |
Author: | Morris 1100 [ Fri Jun 15, 2007 6:49 pm ] |
Post subject: | Re: Fly wheel exchange |
9/61 wrote: Mini and moke world Brookvale in Sydney 9938 2242 Do a flywheel and pressure plate exchange. You give them your flywheel inc. ring gear and pressure plate and they give you a reconditioned set for $99. You can't argue with that! Is that with a new ring gear?
Or is it just dressed up with a grinder? Or is it just looked at and passed as OK? ![]() |
Author: | willy [ Fri Jun 15, 2007 6:52 pm ] |
Do they use gloss black Reconditioning paint? |
Author: | Morris 1100 [ Fri Jun 15, 2007 7:18 pm ] |
A lot of places forget about the ring-gear when they re-face the flywheel and backing plate for exchange. You get what you pay for. Sometimes you may even get what you want. ![]() |
Author: | 9/61 [ Mon Jun 18, 2007 10:04 am ] |
Post subject: | ring gear problem |
Yes you do get what you pay and I paid $99 for a refaced flywheel that was not painted any colour. Its an option depending on your circumstances. If you are in broken hill and needing to replace a ring gear the postage may become an obstacle. |
