It is currently Wed Jul 09, 2025 6:38 pm
PostPosted: Sat Jun 02, 2007 6:53 am
lets just say money is not an option, i want to do up my 1275 engine so what would i have to do to get maximum power out of it?eg. how far should i bore the engine out, what cam should i use etc. all suggestions would be very much appriceated. cheers
PostPosted: Sat Jun 02, 2007 7:04 am
Step 1. Give Engine to Graham Russell.
Step 2. Wait.
Step 3. Wait Some More.
Step 4. Yet More Waiting..
Step 5. Hand over copious amounts of $$$
Step 6. Emerge with fully rebuilt Motor with massive power.
Tip. Listen to what he has to say.
Tip2. Only bore out the engine as far as you need to go. ie next size up.
PostPosted: Sat Jun 02, 2007 7:33 am
What he said...^^ 8)
However it's worthwhile boring to 1330 or 1360 IMO, you still have another rebore or 2 left afterwards. :wink:
PostPosted: Sat Jun 02, 2007 2:01 pm
Turbocharge
PostPosted: Sat Jun 02, 2007 3:48 pm
why not turbo, everyone looks straight past turbo and S/C,
PostPosted: Sat Jun 02, 2007 4:47 pm
Supercharge.
Not better than turbo, I just have no turbo experience, but my mini is supercharged, so I can speak from experience.
Boosted over N/A any day. It's great fun, not too expensive (cheaper than a tough N/A motor) and gives awesome torque.
I got 50hp atws @ 6000rpm from my Cooper S motor, which IO wasn't happy with I expected about 55 but due to lower compression pistons and such no more.
A few months ago I got 75hp atws @ 4900 rpm (Runing too rich and ignition intermittant, couldnt go any higher, now fixed and happily goes to 6500rpm+)
75hp atws (my guess is around 78 now, as it revs much higher and fuelling is much better, but no proof), with stock head, stock cam. Yeah.
Turbo or Supercharge, it's really the only the way to get awesome results. I have a sedate road motor, no silly cams, just nice smoother power. Sure for more Hp you want crazy cams and worked head etc. But I have hot 1275 power without having a hot 1275.
Think of a really powerful N/A A-series, then add 7psi, yeah much better.
PostPosted: Sun Jun 03, 2007 9:04 pm
Turbo injected Twin cam 16v BMW motorbike cyl head conversion
When money is no object & you want the very best , then why bother to do anything less???
PostPosted: Sun Jun 03, 2007 9:09 pm
If you live near matt - then that's the way to go :) you certainly will get lotsa powaaaa! :mrgreen:
