https://ausmini.com/forums/
Cam choice for S/C 1098
https://ausmini.com/forums/viewtopic.php?f=5&t=32083
Page 1 of 2
Author:  PetenSoaf [ Fri May 25, 2007 11:55 am ]
Post subject:  Cam choice for S/C 1098
OK, I've had one of Ben Aford's SC12 kits on a dead standard 998 'trial' motor for a while now - but now it's time to build a proper motor for the supercharger.
The motor will be a 40 thou over 1098 with a 12G295 head. . .it will run 8-ish to 1 compression and have all the usual balancing/lightening etc
BUT
What cam is best to use with a forced induction engine?
Are there any off-the-shelf grinds available?
Does anyone have any practical experience with cams for a blown small-bore?
I assume you wouldn't want a whole lot of overlap but an increase in lift wouldn't hurt. . .would I be better off sticking with a std cam and using 1.5 rockers?
Any advice would be great. . .
Author:  drmini in aust [ Fri May 25, 2007 12:11 pm ]
Russell Engineering RE13T.
:wink:
As used by kazjim's 1152, Benjamin's 1152, boostedmini's 1293. all turbos.
Author:  PetenSoaf [ Fri May 25, 2007 12:16 pm ]
:wink:
Aaahh, yes - overlooked the obvious. . . :oops:
On the Russel Engineering subject, I see that there is aa RE website up and running-ish.
Does GR respond to emails yet?
Author:  drmini in aust [ Fri May 25, 2007 1:21 pm ]
Um... he's never replied to any of mine... :lol:
PC in factory is usually OFF I note.
Better to phone him. :wink:
Author:  slinkey inc [ Fri May 25, 2007 5:06 pm ]
I'm using a standard Cooper S cam, for simplicity and ease of daily driving. Still made 50% more power than it did on twin carbies.
The current owner of the original SC12 mini setup, (not Ben's) runs a fairly sedate cam and still got approx, mid 90s hp ATWS (or so he said).
From what I've read, the best cam for boosting IS NOT, usually, the best cam for N/A applications, you don't want the overlap, but the high lift would be great.
I've seen results here is SA from the RE13T, Sox61 got 72+hp ATWs from his 1098.
Author:  drmini in aust [ Fri May 25, 2007 7:33 pm ]
The RE13T has the same duration and lift as an RE13, but a fair bit less overlap.
Overlap is the killer on boosted engines- the boost tosses fuel mix straight though the combustion chamber and out the exhaust. :wink:
Author:  xplosion77 [ Fri May 25, 2007 10:09 pm ]
is it easy to change the re13 to the re13t because i have a re13 and going to turbo my engine
Author:  drmini in aust [ Fri May 25, 2007 10:11 pm ]
No it can't be done, you need another cam to grind. Angle between the inlet and exhaust lobes (LCA) is wider on the turbo one.
Put the RE13 on ausmini, will be gone in a flash. 8)
Author:  pristic [ Sun May 27, 2007 9:15 am ]
As the doc says, just sell the RE13... instant sale... and get GR to grind you an RE13T
Pete.
Author:  pristic [ Sun May 27, 2007 9:16 am ]
:wink:
I would keep calling. Even when the site is finished, he's more of a phone man than an email man...
Pete.
Author:  sox61 [ Fri Jun 01, 2007 9:56 pm ]
With my set up, I bolted the sc-12 straight on with an RE13 & got ~40hp... Got GR to send me a RE13T and had a mild 30hp increase.
Author:  DOZ [ Fri Jun 01, 2007 11:12 pm ]
If you are talking a supercharged motor then the overlap is less critical (RE13 v RE13T eg). The reason you have less on a turbo is because of the back pressure from the turbo. The air/fuel mix is diluted with exhaust gas during the induction stroke.
You must have a decent flowing zoorst for the blower set-up, this would indicate a typical scavenging approach to the zoorst (remembering that after combustion the exhaust leaves the engine more similar to an NA) so a traditional cam profile would work ok.
You might like to try a cam with an NA lobe separation angle but with a longer exhaust duration? Chew the fat with GR, maybe create a RE13S?.
Daniel
Author:  slinkey inc [ Sat Jun 02, 2007 4:55 pm ]
Now that I would like. But I'm too lazy to change the cam....lol
Author:  PetenSoaf [ Fri Jun 08, 2007 3:22 pm ]
Does anyone have the specs for a RE13T cam (lift/duration/overlap).
I'm not asking for any trade secrets, just a rough idea of the figures so that I can make a few comparisons between the RE13T and a couple of other cams. . .
Thanks!
Author:  volkmini [ Mon Jun 11, 2007 8:06 pm ]
can you run a 1360 with a RE-13t cam with no S/c or turbo while running in the motor.
