It is currently Sun Jul 06, 2025 7:06 pm
 Post subject: 1275 pistons
PostPosted: Thu May 24, 2007 7:00 pm
Any one got correct measurements for 1275 piston, e.g total hieght,hieght from top of connecting hole to top of piston etc i think i may have wrong pistons that came with motor.thanks..
PostPosted: Thu May 24, 2007 7:08 pm
The pistons i have are total hieght 59mm,,,from top of connecting hole to the top of piston is 28mm......from bottom of connecting hole to the bottom of piston is 11mm Is this right or wrong ? Cheers
PostPosted: Thu May 24, 2007 7:50 pm
I have a set of Hypatec pistons from Minisport SA and they measure 28.6mm from top of hole to top of piston. So yours should be Ok.
Cheers Pete
