It is currently Wed Jul 09, 2025 12:28 am
PostPosted: Fri Nov 30, 2007 5:47 am
Hi everybody!
Today I found out, that there realy was an DIESEL A-Series, made in the 60s.
It was build for the "Nuffield BMC Mini Tractor" or "BMC 6/16". a smal, light tractor. Based on the 950cc unit. As data varies, it must have something between 16 and 22HP.
The head is verry different, the sparkplugs have been replaced with big injectors, below them heaterplugs. The valves are nearly even to the block's surface. The injection-pump is direktely driven by a chain from the crank.
Here's a direkt comparison to petrol- and diesel-engine; both were available for the 6/16:
And here some other drawing from an 6/16 repair-manual:
Has anyone ever heard of this engine?
everything indicates it realy is an A-Series - but I still have of no confirmation it REALY is an A-Series. I wasted the whole day to find informations. It's so damn interesting! :D
Could be, someday we'll see an A-Series TDI-Mayfair or something like tis.
Jan
PostPosted: Fri Nov 30, 2007 6:01 am
Yes it was a real tractor I used to sit on them here at shows back in the 60s. :lol:
Matt Read `TheMiniMan' has an original parts book.
Workshop manual download here- http://www.instruction-manuals.co.uk/ca ... CminiT.htm
8)
PostPosted: Fri Nov 30, 2007 6:21 am
Actually that's a really good question: "Is it an A series?".
If the answer is no, because the head and induction etc is (part of) what makes it A series.....then by the same logic an overhead cam head on a mini engine is even less of an A series :wink:
PostPosted: Fri Nov 30, 2007 7:22 am
I've got pix of one. There was one at this years Geelong show.
I've also seen a Morry Minor with the head fitted. It was turbo, too! 8)
PostPosted: Fri Nov 30, 2007 7:50 am
Cold you please e-mail me the pictures?
e-mail is: strassenbelag[at]gmx.net
Yes, I thought that'l be the perfekt head for any injektion-conversation! 1 injetor each port. Perfekt!
I also would like the idea of a dirty, mean and horribly slow Diesel-mini :D
(2750rpm makes about 95km/h w. 13" wheels and 2,75 final - :twisted: )
Jan
PostPosted: Fri Nov 30, 2007 9:37 am
A stock 948 diesel wouldn't have enough power to get out of the way when the lights changed.. :twisted:
Smac yes it IS an A series, sort of.... with a few `additions'.:lol:
I wonder how long their cranks lasted............. :shock: :?
<edit> typo
Last edited by drmini in aust on Fri Nov 30, 2007 10:51 am, edited 1 time in total.
PostPosted: Fri Nov 30, 2007 10:35 am
There is a bigger one on UK eBay at the mo -
Item 200177520322
David L
PostPosted: Fri Nov 30, 2007 1:50 pm
if its an a-series block how would they raise the compression the suit the desiel fuel
PostPosted: Fri Nov 30, 2007 2:00 pm
On the drawings you can see the head is flat. Therefore you would dish the pistons to suit.
PostPosted: Fri Nov 30, 2007 2:04 pm
Flat top pistons and smaller chambers in the head. Notice also that the rear engine plate seems to have a section that bolts to the head. You'd be wanting decent head studs.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Fri Nov 30, 2007 2:44 pm
The design is called `indirect injection', note the small pre-combustion chambers in the head below the injectors, and the constricted passage into the main chamber in the piston crown.
PostPosted: Fri Nov 30, 2007 3:53 pm
i see the little groove on the top of the piston now :roll:
PostPosted: Fri Nov 30, 2007 10:42 pm
the Minor.... was running bio diesel, I'm told that the entire floor at the back has a fuel tank built into it, apparently the Morris Minor Centre in Melbourne had something to do with it - there were other details like performance and economy, but I forget.
Apparently Henry Draper from Melbourne has a pair of the actual tractors
It'd be way cool to put one in a Mini.
PostPosted: Fri Nov 30, 2007 10:46 pm
@simon:
Many thanks!
That thing is soooo damn cool! :D:D Love it!
Looks all stock, somehow... And if you consider Rover to be the first introducing an stock turbo-diesel - it`s a real herald! :)
Here are some other views of head & piston:
I want one!! :D
Jan
PostPosted: Sun Dec 02, 2007 11:34 am
I hear that... same reason I want one!
Users browsing this forum: No registered users and 21 guests
