isleblue65 wrote:
I've just rebuilt my DHLA 45.
34 choke, 160 main jet, 180 air corrector, 50 pump jet, 55 idle jet, 7772.6 emulsion tubes
Its a 1340 with ported Redline 12-3005 manifold and 12G1316 ported head.
Vizard recommended 45 idle jets and 45 pump jets, but the car wouldn't even run until I put the 50 pump jet and 55 idle jet in.
The car has heaps more power now, but if I punch it off idle, it cuts out badly before the power comes back on again. Once going, there are no flat spots, just on initial acceleration.
Should I be looking to go bigger on idle jets, pump jets or emulsion tubes?
I found that the same thing happened on my 998 when I first went over to them. With the Dellortos, the trick is to try a setup, write it down and then go for a drive. Then it is trial and error with the pumps and the Idles - change the idles first and then go for a drive, if that doesnt work go back to the originals and then change the pump jets and so on. Its a bit fiddly but I eventually squared up the balance after a few hours of trial and error.
Webers are good however they dont have the jetting range of the dellortos. However the dellorto stuff is hard to come by nowdays and a lot of the tuners have the micro files and "make their own" type of thing. The weber stuff is plentiful and the setups aim at a band of operation and are a better all round setup if you just throw it on and get it within a ballpark then let the dyno tuner have his way with it(tried both and I prefer the Dell as I have a lot of the jetting for them).
The emulsion tubes are not numbered in a sequential order so a larger number doesnt necessarily mean a larger emulsion tube. The book says 3 tubes(7772.5 - 850/998, 6 - 1275 and up and 7 - 998/1100)are good for the minis and the chokes make a sizeable difference to the setup too. According to Des Hammill(Tuning Webers and Dellortos )the choke size should be 35 or 36mm(yes they do come in odd numbers)but then you would also be remaining with the idle and main jet setup as you have. The 1340 would probably benefit remaining with the 7772.6 emulsion tubes and maybe go to 190 air correctors.
As I said it is all trial and error with these as each setup and engine is unique. I run a completely different setup than that of vizards and the dyno guy said I had it pretty well spot on. The pump lever shouldnt be touched if at all possible as it is set and usually glued there.
Check while you have you noggin under the bonnet and move the throttle and see how much range of movement there is - the pump arm should move immediately when you move the spindle - this gives you your "pump " of fuel as the carb comes up to its progression phase. If it moves a little after the spindle is moved, then you may be starving the engine during that transition phase before the carb comes up on the progression phase.
It shoots petrol clean across my garage when I tested mine - but if you are getting an intermittent spurt, check the diaphragm or adjust the arm itself
Have a play with it though - I knew nothing about them until I bought Makkas Dell and stripped the thing...I played with it for a while and familiarised myself with it - good fun but the Ex hated me smelling like petrol all the time. Have fun.
BTW - I disagree with the heat thing completely - I have the opposite where the carb actually ices up on me. If i leave Canberra I get to the second exit to Goulburn(3 times in a row this happened!!)and the car splutters and misses. I pull over, pop the bonnet and look at the white lump that was the dellorto. 5 mins of heat soaking and all is well again and I have no problems all the way to sydney and beyond - must be the southern highlands thing happening...lol. I have runn the Dell for 3 years and never had a heat issue - more a COLD issue(bastards of things!!!)
Hooroo
