Supercharging with a Weber https://ausmini.com/forums/viewtopic.php?f=5&t=31476 |
Author: | Molina [ Sun May 06, 2007 9:19 pm ] |
Post subject: | Supercharging with a Weber |
At some point i'm going to have to get the gearbox of my mini rebuilt due to it jumping out of second gear a fair bit... at that point i'm considering plans to supercharge my mini. I'm currently running a 45 Weber and really like it. I'd prefer to keep it if possible too. So what i'm wondering is, how hard is it to use the SC12 like lots of other people have but in conjunction with my Weber? I think i recall seeing links to commercially available kits but don't recall hearing of people doing it by themselves. Discuss. |
Author: | slinkey inc [ Sun May 06, 2007 10:59 pm ] |
I've thought about it, without a brake booster it should fit in there, maybe with a nice flexible hose. That way there is no need for a soft mount kit. And you could mount it easily. |
Author: | WasabiPimpNinja [ Mon May 07, 2007 7:53 am ] |
It's certainly possible. All you would need to do is make a new intake joint to suit the weber face like this: ![]() This pic is from the Link Automotive site, and is not the SC12 kit, but the same basic rules apply. From what I've seen and my talks with Ben '92' about the SC12 kit, it mounts "relatively" the same. By that I mean everything goes in much the same place, just different mounts/flanges to suit the different chargers. As for using a weber for supercharging, well umpteen years of motorsport says it's pretty damn good. I'm currently looking at using a weber on my Suzuki Sierra which I'll be dropping an AMR300 supercharger onto. Difference is I'll be running in a blow through set up which means the carb has to be pressurized to stop floats crushing and excess fuel everywhere. No need to do this on a suck through kit. Ben recommends using an HIF44 carb. As far as I know, the main reson for this is because of the new position of the carby, a normal SU could suffer fuel surge during spirited conering. The HIF44 has the fuel bowl directly underneath it and this is the key (from what I'm told). Webers will not have this fuel surge problem. My advice would be to order the kit, take the intake pipe to a fabricator with a weber, and say "Make this bit fit this.". Shouldn't be hard or expensive. If you're handy with a welder, do it yourself ![]() ![]() Peace |
