It is currently Sun Jul 06, 2025 3:06 pm
 Post subject: CAM BEARING INSTALLATION
PostPosted: Wed Apr 18, 2007 1:09 pm
Hi
Does anyone know the correct orientation for fitting the cam bearing that sits beside the oil pump
The ACL bearing has a small notch to draw oil in.
From what i have seen it looks like the notch is at the 6 oclock position facing the pump.
Wouldnt it be better to have the notch at the 4 oclock position therefore away from the max load position caused by the valve spring load?
Anyone have thoughts on this.
PostPosted: Wed Apr 18, 2007 7:17 pm
That space in between the pump and cam bearing gets filled with oil anyway from the pump's bleed hole, I really don't think it matters where the notch goes, oil will get pushed in there. :wink:
PostPosted: Wed Apr 18, 2007 10:12 pm
Cant remember if the mini bearings have a "join" in them, :? if they do, put the join away from the load side.
Michael N
PostPosted: Thu Apr 26, 2007 5:30 pm
with the front one, make sure the big hole goes at the bottom - otherwise the rocker cover will fill up with oil... I think.... someone confirm
