Turbo 1275? https://ausmini.com/forums/viewtopic.php?f=5&t=3103 |
Author: | Gordo [ Sat Nov 27, 2004 7:20 pm ] |
Post subject: | Turbo 1275? |
Hey all i need some info on turbo'in a 1275 motor.. I am lookin at addin a turbo to a 1275 motor, just wantin to know what ill need for this to work?? I want to keep it a carby setup as changin to fuel injected is just too pricy. So i was thinkin a 45mm sidedraft webber maby? Well if anyone could pls give me some info on what needs to be changed or added for a turbo 1275 pls can you let me know CHEERS Daniel |
Author: | minimarc [ Sat Nov 27, 2004 8:55 pm ] |
off the top of my head Differences include Compression ratio Fuel Pump Fuel Regulator need a turbo different manifold use the metro turbo carby bulkhead box head valves and spings should be upgraded cam should be made to suit there are more check out - the turbo mini website www.turbominis.co.uk research it well |
Author: | Kyoda [ Sat Nov 27, 2004 10:05 pm ] |
Check out this thread. http://ausmini.tziworld.com/viewtopic.php?t=2995 JW |
