https://ausmini.com/forums/
how to store stripped down engine parts?
https://ausmini.com/forums/viewtopic.php?f=5&t=3093
Author:  dewey [ Sat Nov 27, 2004 10:32 am ]
Post subject:  how to store stripped down engine parts?
Hey fella's,
I've just finishing stripping down my 998 (which I started doing ages ago) and I wanna put it away at the back of the shed.
Do I need to do anything to make sure the bore stays in good shape while its away? I was thinking just lube it up with some motor oil???? How about storing the pistons, do I need to take the rings off?
dewey
Author:  drmini in aust [ Sat Nov 27, 2004 2:22 pm ]
Thick grease is better than oil, for the bores- it stays on there better.
For the pistons I would leave the rings on, oil them good and then wrap in paper. :wink:
Author:  danidad [ Sat Nov 27, 2004 2:37 pm ]
we use a gell type oil at work which we heat up to spray air filters with. thickens on cooling, but it stays greasy indefinitely so was thinking about cleaning a few of our motors up and spraying the whole thing. i think it would be ideal for preserving motor parts. it comes of without any drama.
if it works out I'll let you know...any thoughts??
