CAM BEARING INSTALLATION https://ausmini.com/forums/viewtopic.php?f=5&t=30662 |
Author: | 73GT [ Wed Apr 18, 2007 1:09 pm ] |
Post subject: | CAM BEARING INSTALLATION |
Hi Does anyone know the correct orientation for fitting the cam bearing that sits beside the oil pump The ACL bearing has a small notch to draw oil in. From what i have seen it looks like the notch is at the 6 oclock position facing the pump. Wouldnt it be better to have the notch at the 4 oclock position therefore away from the max load position caused by the valve spring load? Anyone have thoughts on this. |
Author: | drmini in aust [ Wed Apr 18, 2007 7:17 pm ] |
That space in between the pump and cam bearing gets filled with oil anyway from the pump's bleed hole, I really don't think it matters where the notch goes, oil will get pushed in there. ![]() |
Author: | Clubbie74 [ Wed Apr 18, 2007 10:12 pm ] |
Cant remember if the mini bearings have a "join" in them, ![]() |
Author: | simon k [ Thu Apr 26, 2007 5:30 pm ] |
with the front one, make sure the big hole goes at the bottom - otherwise the rocker cover will fill up with oil... I think.... someone confirm |
