It is currently Sun Jul 06, 2025 9:56 am
PostPosted: Tue Apr 17, 2007 5:48 pm
Looking throught the Engine assembly pages of the SP No. 64 and they mention loads of clearances for everything.
But they note it in ranges.
I know that the larger "racing" clearances offer lower friction, but is there a guideline to go by with all of that lot.
Do you aim for the middle, one end or beyond?
PostPosted: Tue Apr 17, 2007 6:16 pm
as far as i know the larger clearances are there to compensate the higher thermal expansion expected in racing engines.
so the "hot-running-clearences" are about the same, no matter if it's an stock or racing engine
Rover 214 atm ....
PostPosted: Wed Apr 18, 2007 4:25 pm
so where along the range is the clearance set?
PostPosted: Wed Apr 18, 2007 5:03 pm
how do you use it? normal driving with power output around factory level? close to minimum should be fine
Rover 214 atm ....
PostPosted: Wed Apr 18, 2007 5:21 pm
"normal driving"
hmm..
now i need to figure out how i drive, on a scale of Pensioner to willy.. :)
PostPosted: Fri Apr 20, 2007 8:05 am
bump....
"sprited driving"
PostPosted: Fri Apr 20, 2007 3:49 pm
get close to the minimum, if possible
Rover 214 atm ....
PostPosted: Fri Apr 20, 2007 3:57 pm
thanks, tiger..
