5 speed https://ausmini.com/forums/viewtopic.php?f=5&t=30169 |
Author: | sherman67 [ Sun Apr 08, 2007 10:51 am ] |
Post subject: | 5 speed |
is there anyone using a 5 speed box on the road i am just wanting to know what people think of them and what it has cost u to do this process cause i have heard of people that modify the box on there own please any help much appreciated |
Author: | 1360 LS [ Sun Apr 08, 2007 11:56 am ] |
I'm led to believe, better in theory than practice, you'll get the the same results and benefits from changing your diff ratio and other such items. I heard bearing and is it called a sector?? doesn't like the extra gear? anyways this is what I hear. i'm sure someone will give you all the information you're after. Good luck and remember each to their own its your Mini. |
Author: | buztoy [ Sun Apr 08, 2007 1:14 pm ] |
4500 grand from a brit company, there were groups in oz that made em but there now gone ![]() |
Author: | Mini Mad [ Sun Apr 08, 2007 1:44 pm ] |
You are better off spending the money on rebuilding your engine to make more power to comfortably pull a higher diff ratio - which will allow it to sit on the highway at lower revs. Or put a late 5speed jap motor in there ![]() |
Author: | Morris 1100 [ Sun Apr 08, 2007 4:30 pm ] |
Or you could buy a Commodore. ![]() |
Author: | willy [ Sun Apr 08, 2007 4:48 pm ] |
Morris 1100 wrote: Or you could buy a Commodore.
![]() Or a Magna to lose the 'bogan' image and gain the 'grandpa' image ![]() It's real good for cruising nursing homes. |
Author: | Mokesta [ Sun Apr 08, 2007 5:00 pm ] |
willy's new money making trick. Cruise into a nursing home with a grey grampa's car. Sneak around & nick the $500 each that old people keep in their wallets because they can't work out ATMs and have passbook accounts. oops end spam ![]() |
Author: | Spaceboy [ Sun Apr 08, 2007 5:54 pm ] |
http://www.minimania.com/web/Item/MSG4/ ... Detail.cfm |
Author: | simon k [ Sun Apr 08, 2007 8:33 pm ] |
*apparently* they wear the bearings quickly, as the 5th gear isn't supported as well by the bearings and webbing as the first 4 ratios;you can see the 5th gear on this box, to the right hand end of the casing.... ![]() no idea how true this is these days though... minifinity.com may be the place to ask, as most of the members are in UK and have sensible prices for this kind of stuff |
