https://ausmini.com/forums/
Extractors
https://ausmini.com/forums/viewtopic.php?f=5&t=29324
Author:  cookie720 [ Sat Mar 17, 2007 8:41 pm ]
Post subject:  Extractors
Hey im sure that this question has been asked before, but ive searched and I couldnt find anything. Im getting lcb extractors from either minisport or brikworx.
To use the same carb I need to cut the existing one off from the exhaust manifold. When I do this how will the it hold on? It doesnt have any holes for screws on it....
Author:  drmini in aust [ Sat Mar 17, 2007 8:56 pm ]
Post subject:  Re: Extractors
Well...
Some people put them on, line up by eye, tighten and hope for the best. :shock:
I weld up the outer ends of the flanges with MIG, and then file to fit on the studs for location.
I used to braze them up, then found that MIG onto cast iron works well enough for this, and yes, you can still file it. 8)
Author:  cookie720 [ Sat Mar 17, 2007 9:22 pm ]
Your first answer, tighten them with what? if there are no screw holes?
How do you make flanges ? i have a mig welder, can you elaborate please, thanks
Author:  drmini in aust [ Sat Mar 17, 2007 9:36 pm ]
they use the big thick flat washers, standard on that manifold.
I weld onto the ends of the flanges that are there, make em longer Then file a 1/2 round groove. :wink:
Author:  cookie720 [ Sat Mar 17, 2007 9:46 pm ]
Oh thank you very much, thats great.
Author:  drmini in aust [ Sat Mar 17, 2007 10:04 pm ]
Check the thickness of the extractor flanges and the manifold. If different, make 4 stepped washers. I MIG on 1 side on the thick washer, then grind or mill it to the step thickness I want. :wink:
Author:  Spaceboy [ Mon Mar 19, 2007 7:49 am ]
you line it up with the top of the manifold gasket, works every time.
Author:  drmini in aust [ Mon Mar 19, 2007 8:08 am ]
Rough as guts... and after gasket settles, it can drop. :lol:
How about L-R then. :wink:
Author:  sports850 [ Mon Mar 19, 2007 8:17 am ]
I've seen 1/4" difference in between gasket brands for the top of the hole in relation to the top of the gasket , make sure you check where the gasket falls on the head and the manifold before you try the dodgy R us approach .
Author:  slinkey inc [ Mon Mar 19, 2007 4:19 pm ]
Spaceboy you don't have to worry, SC12 kit's manifold fits itself pretty well and was the same thickness as my lcb flanges. Great I reckon.
