It is currently Mon Jun 23, 2025 6:18 pm
PostPosted: Tue Nov 16, 2004 6:21 pm
ok everyone i have set myself a little project for the mini over my 2 weeks christmas holidays and that is to extract more power out of her.
my question is what way to go? i have a budget of around $1000 - $1500
i was thinking about supercharging maybe? or perhaps some more conventional tuning like head work, cam etc?
currently i have got south african mk 111
it has 7.5" discs, and a 1275 with a set of pery extracters and a 1.5" su
internally i have no idea but was rebuilt along with the box about 5 or so years ago by some visiting hot shot who may have done anything and everything to it. the box is good so can apart from a detent plug/pin that lets it jump out of 2nd and reverse if your not carefull. otherwise it's perfect. (hell i drove from mount beauty up falls creek and back to melbourne the next only using the syncro's to change gear (read the topic snowchains for the full story))
it also has electronic ignition .
i'm starting to ramble now, but if anyone has any suggestions, ideas, tips on which way to go and want's to put together a shopping list for me feel most welcome. i would very much apreciate any ideas.
basicly i want best bang for the buck.
cheers steve
edit: oh yeah i'm a mechanic too so i can do all the work myself .
Cheers Steve.
1973 south african mk3, 1275 +30 (1300), RE13 cam, hif44, mildy worked head with s sized valves, pulsar dizzy, 1.5:1 minispares forged rockers.
PostPosted: Tue Nov 16, 2004 6:43 pm
nitrous :D Maybe take the head off and see if anything is done to it and if not then have it worked on and look for a bigger carb.
PostPosted: Tue Nov 16, 2004 10:19 pm
yeah stevo i recon you should go and get her SUPERCHARGED to give her a bit more poke and maybe give sum of de oder people on the road a run for theyre money :wink: ...hope you have fun with your project and good luck :D
PostPosted: Wed Nov 17, 2004 11:46 pm
I've got a question about SUPERCHARGING....
How much will this actually increase the power of your mini?
Like in horsepower/or acceleration speed
PostPosted: Thu Nov 18, 2004 1:00 am
well my m8 has a lancer and it is supercharged and i have been in it wen it wasnt supercharged and with it on it goes like a ROCKET!!!! it depends what one you get realy aussie. his 1 is running 7psi and it run excelent :D
i like chicken
PostPosted: Fri Nov 19, 2004 1:34 pm
$1500 won't cover the blower unless you do it all yourself, and a stockie motor wouldn't do it justice anyway.... I reckon get the a hot cam grind ($100) head ported ($400 ish) plus a HIF44 carb ($150) or Weber/Dellorto ($350). Add on the gaskets etc. to do this work and you're up for a grand by the time you're done and it'll be a different animal
blower can come next christmas, and you'll have the head and cam ready for it
 Post subject: laughing gas
PostPosted: Fri Nov 19, 2004 6:56 pm
laughing gas is way cooler and you could get a set for around a 1000 sure your head will probelly fly threw the bonet the first time you hit the fun button but it will be worth it
 Post subject: Re: laughing gas
PostPosted: Fri Nov 19, 2004 7:30 pm
Is funny gas legal there, here in NSW it's not. Can't have it connected on the street. :cry:
PostPosted: Fri Nov 19, 2004 7:41 pm
i agree, nos = way more fun, but call me crazy some sembelance of longevity is of importance to me
ok forget the pipe dream of supercharging for now.
where should i start?
cam grinds what is good? i have read about the re-13 on here a few times, what sort of specs does that grind have?
weber vs. delorto? correct me if i am wrong but if you can tune a weber it's all the same for a dellorto pretty much? i have very little experience on webbers and i have never actually seen a dellorto beofre. so i will probably leave the tuning bit to the experts.
head work? i have a cylender head specialist that we use at work for machining etc but they also do performance work too. i'm guessing it's just going to be best to leave them to do their thing or could it be an idea to get them some vizard stuff to work off?
cheers steve
Cheers Steve.
PostPosted: Fri Nov 19, 2004 8:21 pm
PM sent. :wink:
PostPosted: Fri Nov 19, 2004 8:48 pm
doc same rule's go down here too for go gas.
ther is actually a jeep wrangler that i have worked on that has a nos system running that the guy uses for competition, scary stuff. it gets trailered around in between meets. it would be registerable and roadworthy if the big wheels (39" swampers) came of it and lost the nos.
cheers steve
Cheers Steve.
PostPosted: Thu Nov 25, 2004 8:21 pm
ok going the tried and tested route with a hot cam, head work and bigger carby.
now the million dollar question: where in victoria should i get my head done at? can anyone put in me in the right direction? i haven't got a whopping budget for an all out race head just yet, am looking for somewhere that specialises in mini's that can do good work with out costing the earth.
anyone got experience with getting head work done any where down here that can give recomendations?
cheers steve
Cheers Steve.
PostPosted: Thu Nov 25, 2004 9:11 pm
yer man
good work with head work.
supercharging (the alley im chasing)
requires more than $1500 :wink:
well so far that's what i've come to find.
head work will be good even if u do supercharge later on, a nice cam will be sweet. Maybe get one for supercharging so u can do the process later on?
while u have the engine off go the centre oil pickup and the centre main strap. then u dont need to pull ur block apart when wanting to stick a supercharger on later down the track.
just ideas
PostPosted: Thu Nov 25, 2004 9:23 pm
dr trim wrote:
centre oil pickup
What the hell mikey! You had no oil to be picked up anyway! :lol:
PostPosted: Thu Nov 25, 2004 9:24 pm
oi
who got u statesmen carpet.
be nice bitch :twisted:
