1100S Large Journal crank Vs 1275 A+ crank https://ausmini.com/forums/viewtopic.php?f=5&t=28889 |
Page 1 of 2 |
Author: | Minimad [ Tue Mar 06, 2007 6:40 pm ] |
Post subject: | 1100S Large Journal crank Vs 1275 A+ crank |
Can someone tell me the difference between these cranks and if they are interchangable??? Can the A+ be modded to go in and 1100s block with the 1100s rods?? Minimad |
Author: | drmini in aust [ Tue Mar 06, 2007 6:43 pm ] |
only physical difference is the A+ one has rolled fillet radii. It bolts straight in an 1100S block, with any big journal rods including 1100S `lumpy' ones. |
Author: | miniobsessed [ Tue Mar 06, 2007 6:56 pm ] |
It all depends... 1100s motors had a 'small journal' crank or a 'large journal' crank - referring to the big end journal size (1 5/8 - small 1 3/4 - large) The A+ cranks I believe are all 1 3/4 but I could be wrong. Something worth considering if you have the small journal 1100s and you're dropping in the large journal A+ is that you can offset grind the large journal to increase your stroke approx 1/8 of an inch ![]() ![]() |
Author: | drmini in aust [ Tue Mar 06, 2007 7:10 pm ] |
He's comparing a large journal 1100S crank with a 1275A+ crank (see title). Both are large journal (1-3/4" crankpins). Offset grinding a crank that has rolled fillet radii is not a great idea really, but has been done. ![]() ,edit> reason it's not a great idea (IMO) is you finish up with a normal ground fillet 1/2 way round the crankpin and a hollow `rolled fillet radius' for the rest. The term `stress raiser' comes to my mind..... <edit 2> here's my 12G1505, 84.33mm stroker crank, after wedging and before final linishing... journal sizes std/std. |
Author: | miniobsessed [ Tue Mar 06, 2007 7:32 pm ] |
fair enough... I'll read more closely next time... |
Author: | Minimad [ Tue Mar 06, 2007 8:16 pm ] |
Thanks Guys As you can probably guess from the multiple different threads.. I am considering either replacing the crank ( a 12G1505) with an A+ crank as the tail has quite bad rust pitting. I know this is a large journal crank, but is the A+ cranks good for a few revs??? This would be to put in my 'race' motor ![]() Motor is currently running full steel main caps Lightened flywheel lighted and balanced rods with hypatec pistons +.20 (and it's an auto block!) Kent MD296 Minimad Ps No stroker motors here...not allowed in historic racing ![]() |
Author: | willy [ Tue Mar 06, 2007 8:52 pm ] |
Graham Russell is building my A+. 40thou over. A+ block A+ gearbox with Tran-X diff. Lightened fly Straight cut drop gears A+ head with extensive work A+ crank, wedged and going to be 'tricked up' a bit A+ conrods, which will be attended to in the weight department. All the other usual bits, Weber etc etc. Hopefully should see 120 @ the fly all going well. I had the choice to go a Small journal, and stroker, but decided that I had already bought enough bits to build up the big J, so I did. The A+ cranks aren't old and abused, as some small J cranks, so this is a thing to consider. All of the Mini Seven racers use these, and don't have issues so I that's good enough for me ![]() edit: You entering in Nc class? |
Author: | Minimad [ Tue Mar 06, 2007 9:04 pm ] |
Yes Nc racing. Haven't got there yet... still "practising" in the regularity ![]() Minimad |
Author: | willy [ Tue Mar 06, 2007 9:11 pm ] |
At least you're out there having a go! I'm still yet to get out there ![]() Mind throwing up some pics of the Mini? |
Author: | Minimad [ Tue Mar 06, 2007 9:37 pm ] |
Author: | drmini in aust [ Tue Mar 06, 2007 9:38 pm ] |
MiniSport UK has A+ cranks on special for £175 I think, with bearings. But it will cost you heaps in freight etc, as my mate Dave Gray (Nb Cooper S) found out. |
Author: | Minimad [ Tue Mar 06, 2007 9:47 pm ] |
Lets try and fix the old one first me thinks........might be cheaper too Minimad |
Author: | willy [ Wed Mar 07, 2007 8:05 am ] |
Fwoor that looks very nice! ![]() |
Author: | HistoricRacingS [ Tue Mar 20, 2007 5:49 pm ] |
Hi Minimad, I've just taken out an A+ Crankshaft out of my race motor. It ran for around 15 meetings before it cracked! Some are good, others not so good. I broke the end off the previous one second time out! HRS PS: Great looking race car! |
Author: | Pin4e [ Fri Mar 23, 2007 10:05 pm ] |
nice looking car |
