https://ausmini.com/forums/
Primary Gear Bearings
https://ausmini.com/forums/viewtopic.php?f=5&t=28888
Author:  Minimad [ Tue Mar 06, 2007 6:33 pm ]
Post subject:  Primary Gear Bearings
I have access to a lathe and am toying with the idea of making my own new bearings for my primary gear
Anybody had a go at this????
What material did you use???
Before someone asks...the tail on my crank is worn and I am planning on having it ground and making the primary gear bearings to suit.... (unless someone has a cheap 1100s crank and primary gear for sale :twisted: )
Minimad
Author:  drmini in aust [ Tue Mar 06, 2007 6:40 pm ]
Yep I made one a year or so ago from LG2 spec bronze, for Cody's GT.
Crank was worn on the front tail bearing so we had it ground .003" undersize.
Bush was a floating design, a copy of the MSC one.
Clearances I used on the bush were .0015" outside, .003" inside, and .010" end float inside the gear.
Dunno if it's running yet- Cody appears to have vanished from the scene... :shock: :?
<edit> this was a front bush only, the rear (ie towards clutch) one was still OK.
Author:  Minimad [ Tue Mar 06, 2007 9:30 pm ]
These threads now go together
http://www.ausmini.com/forums/viewtopic.php?t=28856
Sorry :oops:
Minimad
