Gemini starter motor disengagement https://ausmini.com/forums/viewtopic.php?f=5&t=28874 |
Author: | TasTyger [ Tue Mar 06, 2007 10:14 am ] |
Post subject: | Gemini starter motor disengagement |
Can anyone tell me if theres any way to tell if a gemini starter motor is disengaging from the flywheel by sound or any other method rather than having to pull the thing out again?? ![]() TasTyger |
Author: | DOZ [ Tue Mar 06, 2007 4:04 pm ] |
It would be making a really loud grinding/gear noise if it's not disengaging as the engine would be turning the starter motor. Is there any other symptom you can provide to help out? Daniel |
Author: | drmini in aust [ Tue Mar 06, 2007 6:54 pm ] |
Sometimes you need to put a thin spacer between the Gemini starter and the flywheel housing, it depends where the flywheel & ring gear are sitting. but don't just use flat washers, the starter will rock about. ![]() |
