https://ausmini.com/forums/
998 recommended mods for more torque/overall quality
https://ausmini.com/forums/viewtopic.php?f=5&t=28606
Author:  Smegger [ Tue Feb 27, 2007 6:48 pm ]
Post subject:  998 recommended mods for more torque/overall quality
Hi folks,
I have a 998 with a single 1.5" carb, wildcat 3-1 extractors, decent exhaust, the rest (afaik) completely original. The engine runs well -- good oil pressure, no real noise to speak of, not blowing smoke; all in all, a pretty solid engine.
What have people done in this kind of situation to gain increases in performance? The engine has been well looked after, so afaict it is performing at it's current peak. The difference in performance between this block and another I drive regularly (1100, twin 1.1/4 SU, lumpy cam) is considerable -- I'm looking for tips to bridge the gap.
Cheers!
Author:  TheMiniMan [ Tue Feb 27, 2007 10:28 pm ]
turbo injected twin cam 16valve cyl head conversion should make up some of that difference :-)
sorry, couldn`t help it.
seriously tho, a bigger cyl head/valves/ports, bigger camshaft, better designed inlet manifold & a good tune after all that & you should be sweet
Author:  sgc [ Tue Feb 27, 2007 11:19 pm ]
Hi Smegger :)
I used to own this "other car" :), and when I bought it it had a single 1-1/2" SU. The difference the twins made was pretty significant, especially further into the rev range (I'm sure the cam helped here).
What sort of gain will twins give to an otherwise-standard 998 block and head? Would you get better bang-for-buck with a decent cam and a port/polish?
--s
Author:  Spaceboy [ Wed Feb 28, 2007 1:35 am ]
yeap, work the cyl head, fit twin carbs
Author:  1018cc [ Wed Feb 28, 2007 8:21 pm ]
My 998 still runs the standard cam. When I replaced the carb with HS2's and extractors there was a very noticable difference BUT having said that I know where you're coming from.
The way to unlock power in a A series (any engine really) is to work the head and cam. A port and polish, big valves and a high lift cam would do wonders - up the compression ratio a bit as well if you always have access to high octane fuel.
Author:  1360 LS [ Thu Mar 01, 2007 11:43 am ]
that minus the polish....
Author:  drmini in aust [ Thu Mar 01, 2007 6:22 pm ]
Ain't no substitute for cubic inches.
Only alternative (close) is cubic money... 8)
I'd bung an 1100 crank in, as we do. :wink:
Author:  1360 LS [ Thu Mar 01, 2007 7:01 pm ]
**stroke stroke..... stroke ya engine.... 1100 crank goes in.....port the head suck more air and fill it with some Juice.**
now everybody join in
:P :lol: :o
Author:  Spaceboy [ Thu Mar 01, 2007 11:52 pm ]
yeah, that minus the 1100 crank
