It is currently Mon Jul 07, 2025 10:48 am
 Post subject: Gearbox overview
PostPosted: Mon Feb 26, 2007 10:21 pm
HI guys
I have just popped the gearbox of my motor. Appart from pulling it to bits is there any things I can inspect, measure etc to get a general idea of the overall condition of the box?. Is there things I should be looking for?. All the gears seem to be in good nic theres no apparant wear marks etc etc. The reason I ask is because I have 2 boxes a rod change and a remote change, I want to be able to choose the better one before I spend any money.
Thanks in advance guys
Michael
blokeinamoke wrote:
PostPosted: Tue Feb 27, 2007 9:11 am
All I can suggest is check the condition of the cage in the bearings.
I pulled a box apart once to find bits of the cage missing.
Check the syncros too.
:D
 Post subject: syncros
PostPosted: Tue Feb 27, 2007 12:55 pm
so just check and make sure they are not worn/broken, got it.
blokeinamoke wrote:
PostPosted: Tue Feb 27, 2007 1:46 pm
KC gives a couple of pointers in Mini Expert. Check of movement in the layshaft and sloppiness else where
David L
