Hi all,
I have had my custom 9.25" camira setup for a while now and I am now getting to the stage of re-assembling my front end (after the glorious disassembly). My setup consists of the following:
- Holden Camira rotors with Holden V8/VL turbo calipers.
- Drilled to standard mini (101.6mm) pcd
- New reco'd cv's with new Cooper S tapered roller bearings.
- Original Mini drum brake bearing hubs with a mounting plate for the commodore calipers.
Pics here:
http://www.minimoke.net.au
My main questions:
- What master cylinder should I be running for this setup? I.e. can I use the existing setup?
- This is what I had before disassembling it all (with valiant booster):
http://moke.kelian.net.au/IM000358a.JPG). Will this be ample or will I need to go down the root of a different master cylinder?
- If yes for the above q'n, how will this affect the rear brakes?
- And finally, if yes for the above, what should I be looking at to fit? I have heard the Mazda 323 and Ford laser master cylinders are what I need? Any idea of what model?
Sorry for the copious q'ns. I have done a huge amount of searching on this site and i'll be bu99ered if I can find it.
Ian
My Site:
My Moke: 1978 Californian, 1275 A+, 1&3/4" SU, 9.25" Custom Camira Brakes etc...
Currently Dismantled, Front-end Complete, Body about to be resprayed...
