It is currently Mon Jul 07, 2025 1:23 pm
 Post subject: more sc12 help please.
PostPosted: Sat Feb 17, 2007 10:04 am
Doing a sc12 mod on my 998,
What is the boost pressure off the standard pulley? Would it be wise to get low compression pistons? Also can you get small magnetic clutch pulley to get more boost?
If you can give me info on different boost pressures and piston types that would be great coz im kinda in the dark with that now.
PostPosted: Sun Feb 18, 2007 12:39 am
I am doing the same set up, though a 1098, bored .040 & stock pistons.
Will be getting it tuned next thursday so can let u know what boost it runs with stock pulley..
If you go with low comp pistons then u would need to get a smaller pulley (lower comp, more boost). I wouldn't worry about a clutch type, just a new fixed type pulley.
Carl
