It is currently Sun Jul 06, 2025 11:09 pm
 Post subject: scatter shield
PostPosted: Fri Feb 09, 2007 10:35 pm
I know the concept is to fit it to the clutch slave bolts. anyone got a picture from this angle? i will need one for the 1411cc monster :)
michael
PostPosted: Fri Feb 09, 2007 11:05 pm
And you must won't to protect something when you Rev to hard :shock:
PostPosted: Sat Feb 10, 2007 10:55 am
don't listen to Gaf... he mustn't want any more kids
here are a couple, not the angle you're after, but shows how they're mounted. You can make out a slave cylinder bolt in the top one. Basically use any and every bolt hole in the flywheel housing that points outwards. Wrap it all the way around the motor if you can, and use decent heavy material... something a 5kg angle grinder can't get through quickly
