It is currently Sun Jul 06, 2025 8:24 am
 Post subject: webber on 1098
PostPosted: Wed Jan 31, 2007 4:48 pm
i have a lightly modified 1098 and was thinking of putting a 40doce weber on it but i want to no how much better will it go 8)
@#$%Things are not what they used to be
Missing one inside of me
Deadly loss, this can't be real
Cannot stand this hell I feel
Emptiness is filling me
To the point of agony
Growing darkness taking dawn.
 Post subject: Re: webber on 1098
PostPosted: Wed Jan 31, 2007 5:53 pm
How about you list your modifications then people could advise you better....sounds like a good start for go faster to me so long as it has the correct chokes.
PostPosted: Wed Jan 31, 2007 6:21 pm
as i have said in other posts for me there was huge increase in power and torque, i have a 40 DCOE in a pretty std 1100, My power increases could also have been becuase my su might not have been setup right
77 Leyland Clubman
1293cc, LCB extractors, pulsar dizzy (recurved), cooper s disc brakes, 40DCOE Weber
PostPosted: Wed Jan 31, 2007 6:26 pm
I would go a 1.5 or 1.75" SU on a good manifold.
PostPosted: Thu Feb 01, 2007 2:53 pm
well i have already got a HS4 on it with a 1.75'' exhaust system, KnN pancake filter. goes quiet good but im rebuilding it soon, as it is starting to blow oil out of the exhaust and it is going up the back of the car... im going to stay with the 1098 engine but when i rebuild it i will bore it out 40thou, stick a lumpy cam in it and a modified 202, or 295 head....... how much will it cost for that kind of build???? 8)
PostPosted: Thu Feb 01, 2007 3:59 pm
Depends on how much Hp you want.
Headwork will cost in the mid to high $100's depending on
1) how much hp you want (ie. how much flow bench testing you do and how much material you want to remove
2) how crap the one you have is now(new valves? double springs? acid dip?)
3) unleaded valve seats
4) who is doing the work
Block rebore will cost around $150
New pistons and rings about $200
Seals, gaskets, bearings, the good part of $600 to $1000 for parts only
Cam around $100 to regrind your existing
New cam lifters around $120
New water pump
New oil pump
Then you want to do some modifications... $75 - $90 her hour multiplied by HP wanting to gain dived by about 2 should give you a rough guide! :wink: :P 8)
Lillee - 1969 Morris Mini K
PostPosted: Thu Feb 01, 2007 4:02 pm
i'll have your 1 3/4 when you change over.. ;)
PostPosted: Thu Feb 01, 2007 5:53 pm
I got an HS6 for 40 bucks in great nick form a local wrecker. :wink: . I won't be using it, havn't decided if I will sell it on to a needy user to do my normal style and put it in the shed as 'i might need it later'.
PostPosted: Fri Feb 02, 2007 8:54 am
i was goin to get the engine done in one big hit but i think i will do it in sections, the head is the 1st option followed by Cam, then 10:1 compression :lol:
