webber on 1098 https://ausmini.com/forums/viewtopic.php?f=5&t=27507 |
Author: | MRClubby1098 [ Wed Jan 31, 2007 4:48 pm ] |
Post subject: | webber on 1098 |
i have a lightly modified 1098 and was thinking of putting a 40doce weber on it but i want to no how much better will it go ![]() |
Author: | 9YaTaH [ Wed Jan 31, 2007 5:53 pm ] |
Post subject: | Re: webber on 1098 |
MRClubby1098 wrote: i have a lightly modified 1098 and was thinking of putting a 40doce weber on it but i want to no how much better will it go
![]() How about you list your modifications then people could advise you better....sounds like a good start for go faster to me so long as it has the correct chokes. |
Author: | 72clubman [ Wed Jan 31, 2007 6:21 pm ] |
as i have said in other posts for me there was huge increase in power and torque, i have a 40 DCOE in a pretty std 1100, My power increases could also have been becuase my su might not have been setup right |
Author: | poeee [ Wed Jan 31, 2007 6:26 pm ] |
I would go a 1.5 or 1.75" SU on a good manifold. |
Author: | MRClubby1098 [ Thu Feb 01, 2007 2:53 pm ] |
well i have already got a HS4 on it with a 1.75'' exhaust system, KnN pancake filter. goes quiet good but im rebuilding it soon, as it is starting to blow oil out of the exhaust and it is going up the back of the car... im going to stay with the 1098 engine but when i rebuild it i will bore it out 40thou, stick a lumpy cam in it and a modified 202, or 295 head....... how much will it cost for that kind of build???? ![]() |
Author: | Lillee [ Thu Feb 01, 2007 3:59 pm ] |
Depends on how much Hp you want. Headwork will cost in the mid to high $100's depending on 1) how much hp you want (ie. how much flow bench testing you do and how much material you want to remove 2) how crap the one you have is now(new valves? double springs? acid dip?) 3) unleaded valve seats 4) who is doing the work Block rebore will cost around $150 New pistons and rings about $200 Seals, gaskets, bearings, the good part of $600 to $1000 for parts only Cam around $100 to regrind your existing New cam lifters around $120 New water pump New oil pump Then you want to do some modifications... $75 - $90 her hour multiplied by HP wanting to gain dived by about 2 should give you a rough guide! ![]() ![]() ![]() |
Author: | cush [ Thu Feb 01, 2007 4:02 pm ] |
i'll have your 1 3/4 when you change over.. ![]() |
Author: | slinkey inc [ Thu Feb 01, 2007 5:53 pm ] |
I got an HS6 for 40 bucks in great nick form a local wrecker. ![]() |
Author: | MRClubby1098 [ Fri Feb 02, 2007 8:54 am ] |
i was goin to get the engine done in one big hit but i think i will do it in sections, the head is the 1st option followed by Cam, then 10:1 compression ![]() |
