It is currently Sun Jul 06, 2025 3:42 am
 Post subject: fuel octane
PostPosted: Sat Jan 27, 2007 9:15 pm
hey everyone im running my clubman 1098 engine which has 1.75'' exhaust system HS4 carb and high flow air filter in custom air box.... im running it on 91 octane fule which it seem to go quiet good, i just want to no if it will go any better with 95 octane.??
@#$%Things are not what they used to be
Missing one inside of me
Deadly loss, this can't be real
Cannot stand this hell I feel
Emptiness is filling me
To the point of agony
Growing darkness taking dawn.
PostPosted: Sat Jan 27, 2007 9:20 pm
91 is way too low, Minis were made for Super fuel (was 96-97 octane).
I'd run 98, or 95 if can't get. :lol:
PostPosted: Sat Jan 27, 2007 9:28 pm
oh bugger so in other words it will make a difference with the 98 octane. it should bump the power up shouldn't it and give better throttle response
PostPosted: Sat Jan 27, 2007 9:41 pm
Unless the ignition timing is retarded lots now, I'm surprised it's not `pinging' (fuel pre-igniting due to low octane) on 91.
Put a tank of 98 in, if it's no better, go get it tuned. 8)
PostPosted: Sat Jan 27, 2007 10:00 pm
no i doesn't ping under heavy load, ill advance the timing and run 98 octane in it, ill keep advancing it lil by little untill it pings then ill just back it off.... ill see how it goes.... wat will happen if i advanced it to much. i no that the engine will run hotter, wat are the dangers
PostPosted: Sat Jan 27, 2007 10:20 pm
Too much advance it will run rough, can burn pistons even.
You need to get a strobe timing light, to see what it's set at.
Even a cheapie will do. :wink:
PostPosted: Sat Jan 27, 2007 10:36 pm
yer i have a timing light that i use, but i just wanted to no the affects if i advanced to much
PostPosted: Wed Jan 31, 2007 2:25 pm
I presume a hole in the piston if i advance to much
Users browsing this forum: No registered users and 28 guests
