https://ausmini.com/forums/
??sc12 dump valve??
https://ausmini.com/forums/viewtopic.php?f=5&t=27215
Author:  Monkey998 [ Fri Jan 26, 2007 5:07 am ]
Post subject:  ??sc12 dump valve??
Alright guys,
With the SC12 supercharger kit, does a dump valve need to be fitted off the backfire valve?
i guess the backfire valve is to release the pressure out of the inlet manifold.
Author:  Spaceboy [ Fri Jan 26, 2007 3:48 pm ]
this has been discussed before, cant find it?
Author:  92 [ Fri Jan 26, 2007 4:10 pm ]
The backfire valve vents to atmosphere only in the event of backfire to release the pressure in the manifold as not to damage the SC.
You can't use a blow off valve because as soon as the throttle is shut there is no boost build up as it is a suck through system.
Author:  Monkey998 [ Fri Jan 26, 2007 5:43 pm ]
ah i see, makes more sence now.
Cheers for the help :D
just got to get all the bits for my engine now and build it, cant waite. charger is on its way!
