https://ausmini.com/forums/
Whats my 998?
https://ausmini.com/forums/viewtopic.php?f=5&t=27099
Author:  jbeenz [ Tue Jan 23, 2007 2:05 pm ]
Post subject:  Whats my 998?
Whats my motor?
99h791p 424785
its a late 998 (UK) i think, it has the camxxxx head, with solid rockers etc,
but it also has a 1/2 inch lobe'd camshaft, and the simplex chain is missing its tensioner, there is very little sign of wear, and no evidance that its ever been apart, should a 998 have this cam?
discussion welcomed :P
Author:  Wombat [ Tue Jan 23, 2007 2:24 pm ]
Mini 1000 1974 on with dished pistons
Edit: source http://www.miniresource.com/engine.php
Author:  jbeenz [ Tue Jan 23, 2007 2:36 pm ]
that sounds right, what denotes 74 on?
Author:  drmini in aust [ Tue Jan 23, 2007 6:34 pm ]
the 791
later ones 77 on with smog head were 99H/AJH something. :wink:
Author:  jbeenz [ Tue Jan 23, 2007 7:25 pm ]
hmmmm ok, we never got the smog head here, but its got the unleaded head.
oh dear, to confuse this further, its got an a+ gearbox, with a 3.4 diff.
this is the second similar engine i have pulled down in the last year :?
and whats with this cam, its slot drive, with 2 rings, does the a+ 998 block have ribs?
also the actual engine number seems high.
i dont mean to sound like ive found anything amazing, its just a confusing stock 998
Author:  Wombat [ Tue Jan 23, 2007 10:45 pm ]
You can identify your cam from Vizards book - How wide are the cam lobes?
Author:  KLAS [ Wed Jan 24, 2007 1:35 am ]
does the cam have 2 rised rings between lobe 3 and 4?
and vizards book does not cover all A+ cams
Author:  jbeenz [ Wed Jan 24, 2007 4:52 am ]
yes, 2 rings between 3 and 4, 1/2 inch lobes...
hmmm, i really should buy visards book. :)
Author:  KLAS [ Wed Jan 24, 2007 5:23 am ]
than it should be the normal low compression, 8.3:1, 998ccm A+ cam
Timing: (Intake): 5/45 (Exhaust): 40/10
Duration (Intake): 230 (Exhaust): 230
Author:  jbeenz [ Wed Jan 24, 2007 5:29 am ]
nice and mild then :lol:
thanks for the info! its getting a fresh-up and a nice 202 head, out of interest, what are the specs of a stock pre a+, spider-drive 1275 cam?
Author:  KLAS [ Wed Jan 24, 2007 6:56 pm ]
i don´t know what a "stock pre a+, spider-drive 1275 cam" is.
what engine? or name of the cam?
Author:  jbeenz [ Wed Jan 24, 2007 7:00 pm ]
just the austin/morris 1300 (ado16) cam, its actually a NZ 1275gt cam, which is an a+ block, crank, rods, pistons, with an a-series head and cam :roll:
Author:  KLAS [ Wed Jan 24, 2007 7:47 pm ]
not sure but could be this one:
Timing: (Intake): 5/45 (Exhaust): 51/21
Duration (Intake): 230 (Exhaust): 252
if it is this one, it should be timed in at 106° ATDC and not 110° the manual says
