EFI Rover 1275 in a Morris Van https://ausmini.com/forums/viewtopic.php?f=5&t=26738 |
Author: | Bromley [ Sat Jan 13, 2007 8:06 pm ] |
Post subject: | EFI Rover 1275 in a Morris Van |
I have recently purchased a Rover frontcut with EFI. The plan is to use the existing fuel line with a high pressure pump out of something like a Commodore and run a return line to the tank filler kneck inside the cargo bay. I have done a search on EFI and van and thought that a thread on the subject was justified. Please post any comments and suggestions. |
Author: | Mokesta [ Sat Jan 13, 2007 8:53 pm ] |
Check the fuel pump you select. The SPI injection uses a lower pressure than most EFI cars. May be fine with the rover regulator controlling things. |
Author: | Bromley [ Sat Jan 13, 2007 9:13 pm ] |
SPI = single point injection? Mokesta I have been reading a few other threads with info from you - Thanks. |
