It is currently Sat Jul 05, 2025 6:05 pm
PostPosted: Sat Jan 13, 2007 8:06 pm
I have recently purchased a Rover frontcut with EFI. The plan is to use the existing fuel line with a high pressure pump out of something like a Commodore and run a return line to the tank filler kneck inside the cargo bay.
I have done a search on EFI and van and thought that a thread on the subject was justified.
Please post any comments and suggestions.
PostPosted: Sat Jan 13, 2007 8:53 pm
Check the fuel pump you select. The SPI injection uses a lower pressure than most EFI cars. May be fine with the rover regulator controlling things.
PostPosted: Sat Jan 13, 2007 9:13 pm
SPI = single point injection?
Mokesta I have been reading a few other threads with info from you - Thanks.
