It is currently Sun Jul 06, 2025 5:49 am
 Post subject: Weber and Exctactors
PostPosted: Sat Jan 13, 2007 9:51 am
I found a dcd 28/36 carb on ebay, would this suit a stock engine?
Also i want to have a new exhaust system. Which "Minisport Australia" extractor will suit a stock 1098cc engine?
PostPosted: Sat Jan 13, 2007 2:08 pm
I would probably avoid that weber as the same amount of money can buy you a much better unit. Being a downdraught unit, it might not fit under the bonnet line.
http://freespace.virgin.net/tommy.sandham/weber.htm
You may end up needing to have it stick thru the bonnet like this
some other website wrote:
......The number refers to barrel diameter in mm. The DCD is a twin choke and is really referred to as a 28/36 DCD; the 28 being the primary barrel diameter, 36 being the secondary diameter.....
.....The 28/36 DCD on the other hand may be fitted to 4 or 6 cylinder engines BUT the unit is intended to supply ALL of the cylinders. The function of the two barrels is to provide a compomise between economy and performance. As you quite rightly pointed out, the second choke only opens when the demand from the thottle is high. In fact, the secondary choke does not open until the primary choke is 2/3 open.....
....The principle used to improve the economy with the DCD is directly related to the smaller barrel and hence smaller venturi. With a smaller venturi, better fuel atomisation is obtained when the air flow through the carb is small......
....With the DCD, the cold start device can effectively be considered as a separate carburettor.....
PostPosted: Sun Jan 14, 2007 2:52 pm
So what do you reckon is the best carb to suit my car? Also the flares on that pic, are they factory S pack flares? someone wants to sell them to me for $75
PostPosted: Sun Jan 14, 2007 3:29 pm
Probably just a 40mm DCOE Weber or Dellorto....
Those arches look like Innocenti arches, or maybe something a bit wider. Definitely not factory S ones.
PostPosted: Sun Jan 14, 2007 4:10 pm
where could i get cheap 40mm carbs from in adealide?
PostPosted: Sun Jan 14, 2007 4:25 pm
Steve has a 40DCOE in the workshop, for sale.
Was used on my 998...
Jetting might be close - has 32mm chokes. (or are they 34?. i dunno)
PostPosted: Sun Jan 14, 2007 4:42 pm
is he at minisport or brikworx?
PostPosted: Sun Jan 14, 2007 5:06 pm
whinja ninja
whinja ninja
brickworx
I don't know my name anymore.
