Ignitor electronic dizzy conversion https://ausmini.com/forums/viewtopic.php?f=5&t=26467 |
Author: | Mowog [ Fri Jan 05, 2007 8:47 pm ] |
Post subject: | Ignitor electronic dizzy conversion |
Hi all. I've been told that when you fit the Ignitor electronic conversion to the Lucas dizzy for a '73 car, that the rotor button has to be changed for a different one. Anyone struck this & can help with a part number? Thanks. |
Author: | drmini in aust [ Fri Jan 05, 2007 9:38 pm ] |
Post subject: | Re: Ignitor electronic dizzy conversion |
Mowog wrote: Hi all.
I've been told that when you fit the Ignitor electronic conversion to the Lucas dizzy for a '73 car, that the rotor button has to be changed for a different one. Anyone struck this & can help with a part number? Thanks. This is not true. If you get the right ignitor for the dizzy, the rotor fits as normal. I've fitted up 3 of these. The magnet thingy fits down over the cam, it doesn't interfere with the rotor at all. I buy them here, much cheaper than in Oz. http://www.vintageperformance.com/retro ... /lucas.htm |
Author: | Mowog [ Mon Jan 08, 2007 6:12 pm ] |
Post subject: | Ignitor ignition module |
Dr Mini. Once again, thank you for your help. I've checked out the link & the saving is worth it. Cheers Scotty. |
