SC12 is hard but not too hard. Took my a week and a half to locate one, and about 2 weeks to get the lazy bloke to send it....
Anyways the SC12 isn't that rare, many 4GZE ownbers are getting rid of them to go turbo. BUT the SC14 is much more common. Like very common. SC12 is 1200cc per revolution (close to it anyways) and the SC14 is..you guessed it. 1400cc per revolution.
Availaibility aside the pro and cons of either of them are as follows. Both SC12 and 14 are a Toyota item and are generally in good nick when taken off a car. The 12 comes standard with a grooved belt pulley which can be engineered to work with an A-series quite easily. The 14 come with a toothed belt (or so I've seen) although I imagine the toothed pulley could be swapped for the grooved one. The 12 is a bit shorter, good for tight engine bays. The 12 has it's own oil supply where as the 14 (or once again, so I've seen) connects to the engine and doesn't ahve a dip stick. If you can find and buy (at a decent price, say between 200-300) an SC12, go for it! But an SC14 will work fine and most Jap import places stock them. The 500 and 300 (which I imagine means 500cc per revo and 300cc poer revo) to me is too small.
Just to finsh, the SC12 (which has SC 12 clearly embossed on it and has a dip stick) is found on the 4GZE (and the 4AGZE I think too, but don't quote me on that) and the SC14 can be found on the 1G motor. Both are Toyota superchargers. Plentiful on many import models and some MR2 models
1977 Leyland Mini LS - Project LS-T
