It is currently Fri Jul 04, 2025 3:08 am
PostPosted: Tue Sep 06, 2011 7:42 pm
I'm thinking of getting these spring conversions to replace the rubber donuts in the sub frames, I already have hiLos fitted, has anyone had any experience with these? Are they worth the money? Or time?
PostPosted: Tue Sep 06, 2011 9:46 pm
Minitastic springs got them on both minis, would never go back to cones. Get the fast road
PostPosted: Tue Sep 06, 2011 11:18 pm
i had springs and they always bottomed out and ended up cracking my subframe but if u want them u can buy mine cheep pm me
PostPosted: Wed Sep 07, 2011 9:48 am
Must be some no name ones.
You had the right ones on front and back? As they are different rates.
Have the Minitastic ones for over 15,000ks everyday driving
Never had a problem.
As I Said, Minitastic springs have been around for a while now.
Tried and tested.
Go the fast road kit if you want a decent ride, if you want a modern
Car ride the road springs, you will need to run the car high though..
PostPosted: Mon Sep 12, 2011 12:55 pm
These are the ones I was looking at http://www.minisport.com.au/prod2061.htm
where did you get the minitastic ones from?
PostPosted: Tue Sep 13, 2011 8:12 am
Those ones look like they are the Minitastic ones.
Here is the Minitastic website http://www.minitastic.co.uk/home1.htm
PostPosted: Tue Sep 13, 2011 9:53 am
Sweet Ill just get Em from minitastic save myself a couple of bucks, cheers for the input guys
PostPosted: Tue Sep 13, 2011 10:15 am
if runing 13's you will need a Anti sway bar..
smaller wheels you wont, but as i found out on the swift they rub a bit.
still love them, comfy as.
PostPosted: Tue Sep 13, 2011 10:46 pm
I can testify they crap all over donuts, After being in nicks rover on donuts then his swift mini with springs the springs are a no brainer.
Unless of course youve got a set of hydros kicking about.
Simplify and add lightness
PostPosted: Wed Sep 14, 2011 1:54 pm
Alright sweet I only have 10s and I'm definately going to get them from minitastic, cheers guys
Users browsing this forum: No registered users and 29 guests
