It is currently Sun Jul 06, 2025 7:57 am
 Post subject: Bump Stops
PostPosted: Sat Nov 18, 2006 2:25 pm
i'm converting my car from hydro to dry and i was wondering if there is a rear bump stop. and does anyone have any pics of the rear suspension.
PostPosted: Sat Nov 18, 2006 3:59 pm
no rear bump stop... but no piccy, sorry
PostPosted: Sat Nov 18, 2006 7:05 pm
On a dry car, the rear `bumps stops' are the rubber cones bottoming in the subframe. A dry frame has a bump shape there for this purpose.
PostPosted: Tue Nov 21, 2006 10:32 pm
Here is the Sracer rear bump stop kit.-
http://www.sracer.com/catalog/products/spr015.htm
PostPosted: Wed Nov 22, 2006 5:44 am
You can use competition hydro bumpstops if you move the brake pipe round a bit and tap holes for the attachment plate. :wink:
PostPosted: Wed Nov 22, 2006 1:47 pm
is this worth doing?
PostPosted: Sun Nov 26, 2006 10:15 am
i have the brake pipe on the bottom already. but i just cable tied them up i didn't relocate the little bracket is this a must do will it cause the pipe to come lose if it is just cable tied.
