Turbo Motor at Russell Eng. 244HP on Dyno EDITED https://ausmini.com/forums/viewtopic.php?f=5&t=24764 |
Page 1 of 3 |
Author: | pristic [ Sat Nov 11, 2006 4:37 pm ] |
Post subject: | Turbo Motor at Russell Eng. 244HP on Dyno EDITED |
Howdy, Got these photos from Graham. This motor has 165ft/lb of torque from 4200RPM It increased to 178ft/lb @ 7000RPM and the correction factor was 1.029 (so 244HP!!) There was a slight prroblem with a sticky solenoid... the solenoid sticking caused the boost to bump up to 21.8psi and it produced 186ft/lb before the throttle cable was released! Graham dumped the throttle cable. Pics: >>>>>>>REMOVED AT REQUEST OF OWNER<<<<<<< Cheers, Peter.[ |
Author: | Betty [ Sat Nov 11, 2006 4:49 pm ] |
is that yours pete ? |
Author: | pristic [ Sat Nov 11, 2006 4:51 pm ] |
I wish. This thing has custom injection, intakes, etc, etc... did I mention 244HP ![]() No, mine is beinig assembled at the moment... worked on it today but itll be a baby compared to this thing. Peter. |
Author: | drmini in aust [ Sat Nov 11, 2006 4:58 pm ] |
Awesome!! Yes, there is a mighty A series under there... ![]() |
Author: | Betty [ Sat Nov 11, 2006 5:00 pm ] |
its ok Peter. It's not always good to be fast ![]() |
Author: | pristic [ Sat Nov 11, 2006 5:06 pm ] |
Betty wrote: its ok Peter.
It's not always good to be fast ![]() ![]() |
Author: | DOZ [ Sat Nov 11, 2006 5:20 pm ] |
It's not always good to be fast ![]() Won't be very fast with that torque and an A-series box. ![]() BL reckoned on 94 as the "warranty" limit for metro turbo, hench the electronic boost limiting. Looks like an interesting set-up, go the A-series. Daniel PS - What correction factor was used? SAE? |
Author: | sumanovic [ Sat Nov 11, 2006 6:49 pm ] |
woah ![]() nice engine... so will that all fit in a roundie bay? ![]() |
Author: | pristic [ Sat Nov 11, 2006 6:51 pm ] |
I think its a late model one... Zeemax kit... Doc? Peter. |
Author: | drmini in aust [ Sat Nov 11, 2006 6:54 pm ] |
Graham said it's a Rover or UK shell with a Zeemax kit, so yeah it does. A hole or 2 may be needed for intercooler etc but yes the turbo & plumbing fits up into a standard bay. No `turbo box' required. ![]() Some real work has gone into this puppy..... ![]() |
Author: | sumanovic [ Sat Nov 11, 2006 6:57 pm ] |
nice ![]() |
Author: | drmini in aust [ Sat Nov 11, 2006 7:14 pm ] |
DOZ wrote: Betty wrote: its ok Peter. It's not always good to be fast ![]() Won't be very fast with that torque and an A-series box. ![]() BL reckoned on 94 as the "warranty" limit for metro turbo, hench the electronic boost limiting. Looks like an interesting set-up, go the A-series. Daniel PS - What correction factor was used? SAE? Well Warwick Agustin has campaigned a fast race Mini for many years with a Toyota 4-AGE? chain driving a Mini box, he duels with the VTEC Minis like Borg's out there and it doesn't shed boxes... ![]() A 4 synchro Mini box will stand 180+ HP, for how long IS the question. This turbo beast is in a road car so probably won't get caned after the initial euphoria. ![]() The correction factor used is for air temp ( & maybe humidity?) and barometric pressure on the day. ![]() Engines are run complete with exhaust system, but minus the alternator and fan. Tank cooling is used. |
Author: | awdmoke [ Sat Nov 11, 2006 8:57 pm ] |
That is an intricate & well set up turbo. Awesome figures, hope it justifies the dollars spent ![]() |
Author: | mickmini [ Sat Nov 11, 2006 8:59 pm ] |
been wondering when that thing was going on the dyno, its been sitting there for ages. Warwick broke a drive shaft at the last meeting at Wakefield. it lasted 15 years, and was a modified Morris 1100 item. That is the first breakage that he has had in 15 years in the drive train. mind you it has a holinger straight cut gearset in it. i remember him getting real excited when it arrived at his workshop during the build of that little beast. cheers michael |
Author: | Blokeinamoke [ Sat Nov 11, 2006 9:00 pm ] |
Bloody hell. Thats alot |
Page 1 of 3 | All times are UTC + 10 hours |
